Home > Maintenance & Mods (L322) > Locked out of car!?! |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
charge the battery through the towing socket if you've got one.
1st May 2017 9:21am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Any idea which pin on the plug is? |
1st May 2017 9:52am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3768 |
Martin sells a brilliant connector lead. Look in the shop (next to wiki ).
1st May 2017 9:56am |
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 |
or pull the side repeater out put a feed on the wing indicator to put enough power in the system |
1st May 2017 10:31am |
It is pin 4 in the towing socket with the white cap.
1st May 2017 10:41am |
Am I likely to blow any delta or control units charging by pin 4 or indeed the side repeater? Guessing the side repeater goes through the LCD so assuming no go but the towing electronics is that safe on a trickle? I have a caravan socket and an adapter for standsrd |
1st May 2017 11:06am |
I leave mine connected overnight regularly
1st May 2017 11:34am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7800 |
I always charge mine with the towing socket. Have a CTEK and the adapter from Martin, via the Disco forum.
1st May 2017 1:31pm |
The lead came ready made from Martin, but I assume it uses 3 for earth.
1st May 2017 2:08pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
don't bother with side repeaters it don't work crawl under car and attach to starter don't get wires around wrong way or reset will be needed |
1st May 2017 2:43pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
I have same problem with no towing socket!!!
16th Apr 2020 4:01pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
Ive done this a couple of times on 02 / 03 models works perfectly without probems.. from memory i earther to the underside of the car somewhere metal, If you need to get in and do not have the time to wait for the battery to charge and or cant get under the car the side repeater/ indicator is the go I imagine it would also work on the 2010.. might have to try it one day... after seen that video above im going to see if there is an option like that on the 2010 tomorrow Dave 2010 3.6TDV8 Autobiography Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20 GAP Diagnostics Past - 02 & 03 TD6 And an 1984 Classic |
16th Apr 2020 5:08pm |
Thanks for response.
16th Apr 2020 6:04pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 |
if you have a single trailer socket with a Black cover to it, then it does not work
16th Apr 2020 9:13pm |
