Home > Maintenance & Mods (L322) > Locked out of car!?!
Danwilderspin
Small problem actually big problem - Range Rover has gone completely flat think I left the light on forget that it doesn't have sensor, any way it's so flat it won't unlock but what's worse it that I tried the key in the drivers barrel and it won't work and I can't see a key hole on the boot lid or passenger side - any ideas how I can get in?
Post #436578 1st May 2017 9:03am
andygts
charge the battery through the towing socket if you've got one.
Failing that access the alternator or starter from under the car and attach to the +ve lead and charge. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #436583 1st May 2017 9:21am
Danwilderspin
Any idea which pin on the plug is?
Post #436584 1st May 2017 9:52am
Baltic Blue
Martin sells a brilliant connector lead. Look in the shop (next to wiki ).
He will know the PIN numbers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #436585 1st May 2017 9:56am
HGv driver
Wales
or pull the side repeater out put a feed on the wing indicator to put enough power in the system
Post #436589 1st May 2017 10:31am
Baltic Blue
It is pin 4 in the towing socket with the white cap.
Post #436591 1st May 2017 10:41am
Danwilderspin
Am I likely to blow any delta or control units charging by pin 4 or indeed the side repeater? Guessing the side repeater goes through the LCD so assuming no go but the towing electronics is that safe on a trickle? I have a caravan socket and an adapter for standsrd
Post #436592 1st May 2017 11:06am
Baltic Blue
I leave mine connected overnight regularly
Post #436594 1st May 2017 11:34am
mjdronfield
I always charge mine with the towing socket. Have a CTEK and the adapter from Martin, via the Disco forum.
Out of interest, if 4 is positive I take it you use 3 as earth then, not one somewhere else? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #436608 1st May 2017 1:31pm
Baltic Blue
The lead came ready made from Martin, but I assume it uses 3 for earth.
I have also bought a CTEK, this was just a convenient old photo.
Cheers. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #436615 1st May 2017 2:08pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
don't bother with side repeaters it don't work crawl under car and attach to starter don't get wires around wrong way or reset will be needed
Post #436621 1st May 2017 2:43pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
I have same problem with no towing socket!!!
Do 2010 s still have emergency cable on tailgate??
And is trick on video possible???
 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #550527 16th Apr 2020 4:01pm
Bluegreygreen Rangie 2
Australia
Ive done this a couple of times on 02 / 03 models works perfectly without probems.. from memory i earther to the underside of the car somewhere metal, If you need to get in and do not have the time to wait for the battery to charge and or cant get under the car the side repeater/ indicator is the go
I imagine it would also work on the 2010.. might have to try it one day... after seen that video above im going to see if there is an option like that on the 2010 tomorrow
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #550530 16th Apr 2020 5:08pm
umitbat
Thanks for response.
Is there a way How to decide plus side for repeater? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #550537 16th Apr 2020 6:04pm
pcourtney
if you have a single trailer socket with a Black cover to it, then it does not work
but double 7 pin sockets do - use the white cover socket for power on Pin 4
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
NB Please note that if you have ONLY a 12N socket (7 pins, BLACK cap) as shown in the 5th photo above it does not have the direct battery connection required - you CANNOT charge through this socket.
nice info on all this below
https://www.pfjones.co.uk/advice-centre/to...trics.html
Post #550561 16th Apr 2020 9:13pm
