![]() | Home > Technical (L322) > That issue again , Sorry FBH |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
I don't think this is a new topic , only I have exhausted my search. I have a 2004 TD6 WHICH IN THE Manual says it has AUX HEATING/VENTILATION.
Thanks for replying.
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I have a TD6 and it has a FBH, the unit is located behind the front passengers wheel arch, under the battery.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Could be it doesn't work when the car is upside down... |
Unnecessary quote removed
Will do, but it will probably take me a few days to get to it, and I don't think I have the module in the boot, I believe that's just for remote operation. |
Being a man with no patience, a new toy, and a quick transfer of ownership and unlock code to enable the tool from Patrick in GAP, I can confirm the IID tool will enable the FBH control in the touch screen menu. |
Ok thanks , ir seems that unless the mosule is there at all , then its all.downhill |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
Preheater on mine comes on at 15 degrees or below. I think 15 has been standard for a while. |
