Home > Technical (L322) > That issue again , Sorry FBH
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
I don't think this is a new topic , only I have exhausted my search. I have a 2004 TD6 WHICH IN THE Manual says it has AUX HEATING/VENTILATION.
I haven't had the car long but would like to have all things working as they should.
There is no heat option on the screen menu only ventilation.
So according to some you can enable , there is no webasto module in the rear but it does have a pre-heater as I hear it and within less than half a mile this am . I could feel heat. So what do I do next , I removed fuse 59 to reset as it has been suggested , but no luck.
Pat
Post #436183 28th Apr 2017 5:58am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
The module in the rear is for the remote fob.
on the screen settings menu go to timer controls, you can preset the timer to go on at a certain time, and that should last for 30 mins.
the preheater will come on when the outside ambient temperature is around 8 deg Celsius or below.
the fobs and modules are available on the bay of e, and will need pairing, I have the module in mine but no fob, and tbh I really don't need it.
fyi, all td6's came with the preheater, it was an option on the petrols.
greg Thumbs Up
Post #436204 28th Apr 2017 8:27am
alfapat
Thanks for replying.
Your right, not required really but....., so it's not available on screen on mine and would be if I had the module? Are there spare plugs for this connection and where does the module live , do you know please.
Meantime I'll look for it online.
Sorry I've just reread post module in rear!
Sorry about upside down pic! Smile
Wayhay!
Post #436210 28th Apr 2017 9:46am
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I have a TD6 and it has a FBH, the unit is located behind the front passengers wheel arch, under the battery.
The timer doesn't appear anywhere on my screen menu either, when I bought my FF the fuse had been removed, I refitted it and it worked but as previously stated, only when the OAT is below a certain value.
I don't know if the timer can be enabled in the menu, I have an IIT tool on order so I'll take a look when it arrives but as it stands, it comes on automatically below a certain temp., all be it a little smokey but I put that down to non use while the fuse was removed.
Post #436220 28th Apr 2017 11:19am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Could be it doesn't work when the car is upside down... Rolling Eyes
Post #436236 28th Apr 2017 1:38pm
alfapat
Laughing
Post #436264 28th Apr 2017 4:13pm
alfapat
Unnecessary quote removed
Can you let me know if the IID Tool enables please, do you have the module in the boot?
Post #436265 28th Apr 2017 4:16pm
hamlet
Will do, but it will probably take me a few days to get to it, and I don't think I have the module in the boot, I believe that's just for remote operation.
Post #436267 28th Apr 2017 4:35pm
hamlet
Being a man with no patience, a new toy, and a quick transfer of ownership and unlock code to enable the tool from Patrick in GAP, I can confirm the IID tool will enable the FBH control in the touch screen menu.
Post #436286 28th Apr 2017 8:04pm
alfapat
Ok thanks , ir seems that unless the mosule is there at all , then its all.downhill
Post #436301 28th Apr 2017 10:05pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Preheater on mine comes on at 15 degrees or below. I think 15 has been standard for a while.
Post #436320 29th Apr 2017 9:01am
