Home > Technical (L322) > Vibration at around 40mph.......Diff problem?
Page 6 of 7 <1234567>
jinkytoby
Whistle pleased its fixed Whistle ( previose post) """HI im a new member here but to add to the others i would say it was torque converter as i had excactly the same problem as you descibe to the word..t/c changed problem gone away""" . id want my moneyback from the joker at the garage who said it was injectors Evil or Very Mad
Thumbs Up[/u]
Post #87389 14th Oct 2011 4:36pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Excellent news Paul Thumbs Up
I had the new torque converter fitted last week so I can relax now Cool
Luckily at the same time, the mechanics noticed that a drive shaft was warn out (Rear ball joint?), Too stiff to move by hand so they ordered a new one for me as it's still under warranty, but got sent the wrong part Rolling Eyes
Should be fix my the end of next week with the correct part.. Fingers crossed Mr. Green
Can only give top marks to my dealer Thumbs Up
Post #87407 14th Oct 2011 5:28pm
RRPhil
I too now have the the ‘cattle grid’ noise & vibration on my ’03 4.4 V8 (with 107k miles) and I thought I'd have a go at using my Blackbox Faultmate to see what the torque converter lock-up clutch is up to and it clearly shows that the LUC is unable to maintain a constant slip rate even when the vehicle speed and throttle angle are constant. The current supplied from the transmission ECU to pressure solenoid 4, which supplies hydraulic pressure to the lock-up clutch, is practically constant too yet the engine speed is all over the place.
The stick-slip characteristic can be seen in the converter’s speed ratio which hunts up and down, giving rise to the vibration.
Converter requires replacement ASAP methinks .........
Phil
Post #89541 30th Oct 2011 6:28pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
The faultmate is a nice bit of kit Phil.
I wish I could justify the outlay on one.
Good luck with the work Smile
Are you putting an upgrade TC or original LR?
Post #89547 30th Oct 2011 6:55pm
mrd1990
For me, it's been almost 8 weeks without the range rover.
Had the new torque converter and a new drive shaft, but the vibration is still there Shocked
It's getting it's 3rd Gearbox fitted today, last one was only a 6 month old reconditioned box...
They said it may have been fitted incorrectly.. something to do with a valve not opening? Controlling the pressure in the TC I guess.
Fingers crossed for the new box Neutral
Post #90148 3rd Nov 2011 12:31pm
mrd1990
12 Range Roverless weeks later.. it's fixed Very Happy
The culprit was the injectors, previous owner had fitted the wrong injectors (incorrect serial no.) new correct set installed, perfect ride.
Driving a range rover for the first time in 3 months makes you appreciate every little inch of it Thumbs Up
Post #96764 8th Dec 2011 7:10pm
PaulB
Wow, you have a new motor.
Glad it's sorted, I presume the cost was covered by somebody else?
I had the opposite, they changed the injectors first, TC last.
Post #96801 8th Dec 2011 10:11pm
mrd1990
Well the word perfect was a little ott
it was under warranty when it went in.. dodged a bullet there
But now I have bad vibration under breaking Shocked and continuous vibration at high speed but only in the steering wheel.
I suspected the wheels or rotors are damaged but the power steering doens't seem very powerful Thud
6 months of ownership, it's spent half that in the repair shop Laughing
Post #96907 9th Dec 2011 6:25pm
PaulB
Banging Head
Post #96914 9th Dec 2011 7:01pm
brunofarare
Sweden 2003 Range Rover Vogue 4.4 V8 Giverny Green
Hello everyone.
I'm new here. Just read through everything, very interesting reading. I have a similar problem on my Vogue - 03 4.4V8. The difference is that the sound and vibrations start at 95km/h (approx. 59mph) and fades away around 115km/h (approx. 72mph). It only appears in 5th gear, auto and manual, especially if you push gently on the throttle so it doesn't gear down to 4th. Any ideas what that could be? Perhaps the torque converter as well?
Brgds
Carl
Post #159597 23rd Dec 2012 7:13pm
@ brunofarare
Sounds like wheel balancing, 50 - 65 is the classic speed for this ? You may not get a wobbly steering wheel but you will get vibration/noise. .
Post #159598 23rd Dec 2012 7:17pm
brunofarare
I thought so as well before but i have two sets of tires, summer and winter. The summer set is on 19" 255/55 and the winter is on RR Sport 20" 265/50. The sound and vibrations occur on both set of tires. It disappears if i put in N and it comes back when i engage D and gently push the accelerator again (in 5th gear between 59-72mph).
Brgds
Carl
Post #159644 23rd Dec 2012 8:53pm
Well that eliminates wheels Thumbs Up
Do you get the same vibration at that speed in 4th gear (go Sport or Manual) or even 3rd gear if you dare? This will help to identify whether on the final drive or before it (5th gear specifically) .
Post #159741 24th Dec 2012 1:47am
mrd1990
Could be worn brake disk and/or sticky caliper
Post #159792 24th Dec 2012 11:09am
jumbaleo
This is a super old thread, but the Vibration at speed that can be felt through the drivers seat / through the steering wheel at 50mph plus and then disappears when you put your foot down hard..
Has anyone ever considered it being the TPMS throwing the wheels totally out of balance?
I am on my 2nd L322 the first being a 3.6 tdV8 and now I have a 5.0 S/C and I have exactly the same issue. Someone from an independent specialist recently suggested they have so many cars coming in with the same issue, but its normally down to TPMS on all the wheels throwing out the balance.
Just a thought? 2010 - 5.0 Supercharged, Autobiography
2007 - 3.6 tdV8, Vogue
Post #436247 28th Apr 2017 2:56pm
