Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 14 of 14 <123 ... 121314
Smiffyuk2017
Hello lukie
If I'm honest I don't know 🙈
Basically I've tapped into the wires on the gear shift, tiptronic side, it works with the normal type of micro switch (the bigger kind with the metal lever on, I've got 2 wires for shift down and 2 wires for shift up and when I touch these it powers to shift up, sorry for my lack of knowledge 😀
Post #431386 16th Mar 2017 9:12am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
ok well it can be made to work, the wireless 2ch relay system should be good for you, will be working on my wireless system shortly
Post #431442 16th Mar 2017 10:22pm
Amiyanji
United Kingdom 2010 Range Rover HSE Td6 Fuji White
Paddle gear shift on a 2010 Range Rover Sport 3.0 HSE
Hello,
Can I fit the paddle gear shift on a 2010 Range Rover Sport HSE 3.0.
Thanks
Post #435875 25th Apr 2017 5:02pm
you might want to register on the RRS forum,
this info is from there,
http://www.rrsport.co.uk/forum/topic25378....ddle+shift
http://www.rrsport.co.uk/forum/topic17399....ddle+shift ... - .- -.
Post #435876 25th Apr 2017 5:37pm
Amiyanji
Thanks for the info, I will check it out.
Thanks again
Post #435884 25th Apr 2017 7:02pm
j_rov
Has anyone got a part number for the cable that connects the blue plug to the button cluster on a 2010 model please? __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #487457 29th Aug 2018 5:03pm
datafoo
United States 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
Bumping an old thread with updated info.
For the MY10-MY12 install:
FYI the cable everyone wants is a standard 4 pin, 2.54mm spacing jumper cable. Right now they're easy to find on ebay as "arduino jumper cables" or something similiar.
I'd order a 20cm (8") flat cable as anything larger gets hard to stuff back in the wheel.
If anyone wants to build cables the LR connections are Tyco Electronics or TE MQS connectors. The slightly differing part numbers are indicative of which way the "L" goes as they are opposite.
TE Internal #: 3-1355397-3 Female to paddle shifter.
TE Internal #: 2-1355397-3 Female to steering wheel controls.
As mentioned before the steering wheel controls side is wired Left to Right starting from the "L" corner: red-gry-blu-blk. Match up the blue paddle side connector so it is also wired up red-gry-blu-blk.
I built a cable using spare parts a bit shorter than I should have but got it working.
Great thread! 2012 L322 SC Ipanema Sand
2012 L322 Autobiography Santorini Black
2006 L322 HSE LUX Zambezi Silver
Newton's 42nd law: If you run around a tree fast enough, you will inbox yourself. Quotes are silly.
Post #527214 6th Sep 2019 9:52am
