![]() | Home > Technical (L322) > LEAKING SUMP PLUG |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7881 ![]() ![]() ![]() |
You could always file it back slightly and fill with liquid metal perhaps? 2011 Range Rover Vogue SE 4.4 TDV8
david lanceley Member Since: 24 Jan 2013 Location: UK Posts: 6 ![]() ![]() |
Thanks Martin. Something I've considered but would be good to know if anyone has done it successfully. |
I've only seen it work on a gearbox casing.
You can remove the sump in-situ, but the front diff has to come out first according to RAVE:
Double post |
Thanks Joe90. Doesn't look too challenging a job although perhaps not for the faint-hearted....
Quite convoluted, suggest download RAVE:
Thanks Joe90. Downloaded OK but struggling to open the files. Most seem to be labelled P38 or Defender? |
