Home > Technical (L322) > LEAKING SUMP PLUG
david lanceley
2004 Range Rover Vogue Td6 Santorini Black
LEAKING SUMP PLUG
Just completed service and oil change on my 2005 TD6. There appears to be a very slow leak from the sump plug and on looking at it seems to be a crack running from the plug hole for about one inch.
Spoke to a few people about fixes, generally doom and gloom as can't weld insitu.
Any thoughts?
Can the sump be removed with the engine in the vehicle?
Post #435672 23rd Apr 2017 1:33pm
mjdronfield
You could always file it back slightly and fill with liquid metal perhaps? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #435673 23rd Apr 2017 1:35pm
david lanceley
Thanks Martin. Something I've considered but would be good to know if anyone has done it successfully.
Post #435676 23rd Apr 2017 2:06pm
mjdronfield
I've only seen it work on a gearbox casing.
I'm Mark - all the emails from the site are sent from Martin, that's the email account the site uses, the senders username is in the text of the email.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #435679 23rd Apr 2017 2:17pm
You can remove the sump in-situ, but the front diff has to come out first according to RAVE:
Post #435687 23rd Apr 2017 3:36pm
Double post Rolling Eyes .
Post #435688 23rd Apr 2017 3:36pm
david lanceley
Thanks Joe90. Doesn't look too challenging a job although perhaps not for the faint-hearted....
I have a 4 post ramp so access is good, decision is whether to attempt myself or give to the pro's
Would you happen to have the process for removing the front differential?
Post #435695 23rd Apr 2017 3:56pm
Quite convoluted, suggest download RAVE:
Direct Link .
Post #435752 23rd Apr 2017 11:26pm
david lanceley
Thanks Joe90. Downloaded OK but struggling to open the files. Most seem to be labelled P38 or Defender?
Post #435784 24th Apr 2017 1:58pm
