![]() | Home > In Car Electronics (L322) > Coding DSP Amp? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2222 ![]() ![]() ![]() |
Bump |
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 ![]() ![]() |
Can you expand upon the question, please?
Hi Zulu - can you tell me the commands to set the crossovers as they are set to e39 ? Also do you know the commands to set the fade to standard?
Fade to Centre is 68 04 6A36 80 B0
Hi Zulu
Firstly, was Navcoder seeing and displaying all the usual bus traffic around the car, thus proving that it and the interface are both working correctly?
Good thinking! |
Just thinking about it this may fix my fader issue but the crossover issue needs to be coded so this would not be a full fix.. |
As I see it you have a number of options for a permanent fix:
