Home > Technical (L322) > IID TOOL diagnostics -
gillech
Switzerland 2003 Range Rover HSE 4.4 V8 Adriatic Blue
hi,
please could someone advise me on the fault reported by my IIDTOOL :
VIN: SALLMAMA42A******
L322 - Range Rover 2002
Vehicle scanned on 10-04-2017 13:16
Using IIDTool BT V3.0 B2193
ECM-Engine (ME7.2)
0x43E Multiple misfire fault
0x439 Misfire detected cylinder 2
is this a problem about spark plugs, alternator or simply wires or contacts ?
what should i check and in which order ?
i must add that I cleared the fault and it has not appeared again since.
thank you
Post #434490 10th Apr 2017 6:17pm
dingg1
forget it until (or if) the fault comes back
Post #434492 10th Apr 2017 6:39pm
gillech
thank you,
I am asking precisely because my engine default sign went off on the dash repeatedly 3 times during the last week, and i could not find out the fault using the IIDTOOL.
it went off again today,i could get the diagnostic with IIDTOOL, and so i am getting a bit concerned something might be wrong in the engine .
Post #434494 10th Apr 2017 6:49pm
dingg1
ok - maybe a bad batch of fuel ?
if its running okay now and not showing any codes thats the most likely explanation
if it comes back as cylinder 2 miss , could be plugs or coil pack
Post #434495 10th Apr 2017 6:51pm
gillech
ok thank you.
is there a way i can check the ignition coil using IIDTOOL ?
Post #434497 10th Apr 2017 7:28pm
cass
Swap the coil to another cylinder and see if the problem moves to that cylinder
Post #434499 10th Apr 2017 7:41pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
A burgeoning faulty coil sometimes manifests itself when it gets hot. A friend had a similar fault on a Volvo and after leaving it at a dealership overnight they couldn't find the fault. When he was driving it home however it pinged up a fault. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #434567 11th Apr 2017 8:25am
