Home > Technical (L322) > Now ive fixed the door lock, and got a pleasant surprise
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
After Saturdays fiasco I searched more threads and decided that this morning I would take out the lock cylinder and have a look to see if there was anything fouling it. I realised on peering into the hole that there is a shape on the end of the lock cylinder shaft that should be inserted into the corresponding hole in the latch mechanism. When I lined it up it went back in with no problem and the outside lock now works fine. To get at this properly I had also removed the door airbag which meant disconnecting the battery. Whilst it was disconnected I carried out a hard re-set and, to my surprise, when everything was reconnected and put back together the door central locking worked. I dont know whether it was the battery re-set, disconnecting/reconnecting the electrics or the general banging about the latch received that got it working (it will probably stop again tomorrow), but it means that the ff is currently problem free (now Ive gone and jinxed it). QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #434387 9th Apr 2017 8:22pm
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
lock
what a great feeling when somthing goes right well done Thumbs Up Thumbs Up Thumbs Up
Post #434416 10th Apr 2017 6:07am
andygts
Is not refetting the lock cylinder properly some sort of anti theft advice thats knocking about somewhere or just incompetence on someones behalf. Both of my FFs had been incorrectly fitted when I bought them and after an expensive near miss with a Corrado VR6 years ago I always check the key fits all the locks.
Unbeknown to me the Corrado had had a new ignition barrel at some point in its life and when I bought it only got 2 keys and 2 fobs of which one worked. You can guess what then happened to the fob. Luckily open heart sugery saved it and I learnt how to take a lock barrels to pieces and configure it to my key. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #434431 10th Apr 2017 10:09am
i have found that on most electrical/electronic faults or glitches on the FF , a battery disconnection to reset the ecus is a good first step... ... - .- -.
Post #434433 10th Apr 2017 10:18am
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
Is there any other benefits to a battery reset ? or will it cause any new problems ?
Post #434478 10th Apr 2017 5:48pm
Spelunker
I knew I would jinx it - the drivers door central locking has stopped working again. I wonder if it is a bad connection/broken wire that I disturbed.... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #434658 11th Apr 2017 9:00pm
Spelunker
I dont know if there are any down sides to a battery re-set (as long as you follow the correct procedure) but it has cured a number of faults for me over the months. QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #434659 11th Apr 2017 9:02pm
