![]() | Home > General > Thinking of buying an 07 tdv8 - its very cheap! |
JohnJ Member Since: 22 Apr 2016 Location: Varese Posts: 41 ![]() ![]() ![]() |
4.000 GBP? the price seems suspiciously low... having said that, if you put aside a few spare thousand pounds for repairs and fixes, you should be fine. The only real risk would be if a new engine is required, it would set you off a significant amount of money... Mileage? 2011 Vogue 4.4 Santorini black
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
The one thing these cars don't seem to like is being sat around for long periods. If it simply stopped working on their drive one morning it is * probably* something simple..but as said above..budget for potentially needing a chunk of cash for recommissioning. Maybe get an AA / RAC inspection? It may be a good 'un!
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
What is the symptoms of a thermostat housing leaking? Just curious.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
If you don't have it I will |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
can't loose much @�4000, break it down to bits and you'll get more in parts than as a whole car! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
as said its worth more in parts.
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
I'll join the queue if you dont want it. 2007 Vogue TDV8 with 255/55/20's fitted |
Again, Even if it is the engine and she's ingested either her turbos or EGRs you can get them fixed.
^thats right you did, was not for the feint hearted though. There is nothing that can't be fixed with a hammer😜😜
Dropping coolant level...beginning to drop quicker...no leaks underneath as the engine evaporates it until it gets really bad...I was on the look out for it as it has a plastic manifold in the middle of the V like my MG ZTT 190...eventually they go...just shine a torch into the V...you will soon spot any orange coolant down there! (Sometimes it is just the two short pipes from the housing down into the engine...but after all the faff of getting to it, for �65 you are better off doing it anyway..) |
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 ![]() ![]() ![]() |
Did you get it bought ? |
