Home > Technical (L322) > Spongy brakes when engine running
Mac1971
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Strange one as when engine not running pedal is rock hard yet when running the pedal falls as though master cylinder seals passing . Anyone had similar ?
Post #433502 1st Apr 2017 8:10pm
How quickly? The pedal will be hard with the engine off, generally a lot softer when running. Shouldn't go to the floor, but may creep down when you press it. Never been sure if this is right tho, but have experienced it several times on different t cars. There is nothing that can't be fixed with a hammer😜😜
Post #433503 1st Apr 2017 8:13pm
Mac1971
I wouldn't say quickly , brakes work ok just never experienced this .
Post #433505 1st Apr 2017 8:19pm
Weegie
If you mean that you start the engine with your foot on the pedal and the pedal sinks a bit then that is quite normal. It shows that the servo is working.
On the other hand that might not be what you mean. Confused John
GAP iiD BT
Post #433531 2nd Apr 2017 6:59am
