![]() | Home > Technical (L322) > Spongy brakes when engine running |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
How quickly? The pedal will be hard with the engine off, generally a lot softer when running. Shouldn't go to the floor, but may creep down when you press it. Never been sure if this is right tho, but have experienced it several times on different t cars. There is nothing that can't be fixed with a hammer😜😜
Mac1971 Member Since: 17 Jan 2016 Location: Hartlepool Posts: 30 ![]() ![]() ![]() |
I wouldn't say quickly , brakes work ok just never experienced this . |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
If you mean that you start the engine with your foot on the pedal and the pedal sinks a bit then that is quite normal. It shows that the servo is working.
