Home > General > Coming up to my first anniversary
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
It wont be long until it will be a year since joining the FF ownership fold. In that time I have had to call out the AA three times to it, had a door mirror kicked of, been sideswiped and had numerous electrical faults (no mechanical ones so far thankfully). This is more than I have had to put up with in 40 years of car ownership and I must admit I have yet to come to love the car in the way that I have with some of my previous vehicles, but it is still there on the driveway and I am willing to give it another year or three..... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #433271 30th Mar 2017 7:06pm
nar53
France 2002 Range Rover Vogue Td6 Giverny Green
I'm a couple of months past my 1st anniversary. Luckily no major probs so far, replaced the FSR & Disks & Pads all round when I first got it. Coming up to its first service with me very soon. Only other thing, the less than two year old battery seems to be on its way out, but thats another story!
Good Luck
Nigel
Post #433399 31st Mar 2017 9:53pm
Spelunker
The 3 times I called out the AA was due to the battery. Twice whilst on different holidays and once on my drive the battery was completely dead (after standing a maximum of a day). I had replaced the original battery with a brand new one of the correct size only a week after getting the car, but in the first two call-outs to the AA I was told there must be something causing a drain. It was only after the third call out (about four months after the first) that I was told the battery was at fault. Sure enough, when I returned to where I had the battery from and had mine checked it was faulty and replaced. This was last November and there hasn't been a problem with the battery since. QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #433592 2nd Apr 2017 5:51pm
Goldy
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Just approaching my 12 months.
Drivers side air bag popped and towed home.
3/4 Flat batteries (due to short trips and days without being run as per AA)
Lambda sensor causing engine light and judder (covered / and repaired under AA)
1 x parking ticket - still fighting.
Not bad compered to some but more trouble than any other car I've owned.
Post #433812 4th Apr 2017 12:52pm
KRV24
My one year anniversary is just 3 days away, never had a FFRR before but took the plunge! I have thoroughly enjoyed driving the beast and there is simply no comparison on the motorway.......However, it does give me a squeaky bottom every time I think something might or has gone wrong Shocked
But I've only had a starter motor failure and a split intercooler hose and consider that so far so good. Very Happy The battery did go flat once and despite the AA man telling me I needed to replace it, i invested in a CTEK 5.0, left on a charge overnight a couple of times and battery has been fine ever since. I even left the car in a long stay car park for 15 days and it fired up first time! Go figure?
Last but not least, the FFRR journey has been made infinitely better thanks to the good folks on this forum, I solute you comrades Thumbs Up Range Rover Vogue SE 2010
Post #433833 4th Apr 2017 5:12pm
Roystonh
Second anniversary here so it is now 6. Mechanically EGR valves replaced when I bought it and just had handbrake repaired Under warranty. Other than that just routine servicing - was considering changing up but keeping this one for a few years. First L322 12 years ago. Engine makes me smile - happy boy! 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #433834 4th Apr 2017 5:17pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
4 and half years ish.. would make your eyes water seeing the total of the invoices !
2003 4.4 Litre FullFat
1. Alternator
2. Expansion Coolant Tank
3. Few Coolant pipes replaced
4. Water Pump (under warranty)
5. Front Radiator
6. Two front air suspension air bags (under warranty)
7. Parking sensors x3 (under warranty)
8. Headlight control module (under warranty)
9. Door lock assembly (under warranty)
10. Rockers Cover Gaskets
11. Brakes pads all round
12. Discs all round
13. 2x sensors for brake pads
14. Rear hub O/S upper bush
15. 2x front brake pipes
16. Front anti roll bar link (under warranty)
17. heater resister (under warranty)
18. Gearbox rebuilt and torque convertor replaced at 86900 Mileage (under warranty)
19. Front/Rear Diff Oil Changed
20. Transfer Box Oil Changed
21. Suspension Air Compressor (Under Warranty)
22. Left hand side wheel height sensor suspension (under warranty)
23. drivers side seat control unit (under warranty)
24. front left passenger side wiper motor failed replaced (under warranty)
25. PVC oil system pipes failed replaced 2 pipes.
26. Full Engine Refresh (all done same time)
New Timing Chains all three
New Timing guides
Cam Tensioners
Side Tensioner
Front Main Seal
Brand New Vanos Units (no more diesel sound)
Front Radiator again as leak
Thermostat
Gearbox Cooler
Power Steering Pump Refurb
Pully Wheel
Replacement Belts
Vanos Solinoids
All New Gaksets.
(Part Under Warranty but not a lot !)
29. Rear window Wiper Motor Failed and Replaced
30. ABS Sensor Replaced
31. ABS ECU Replaced
32. New Fuel Pump 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #433836 4th Apr 2017 5:27pm
Spelunker
Wow - good job you had the warranty. QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #433853 4th Apr 2017 7:18pm
