![]() | Home > Technical (L322) > Oil leak from dipstick tube |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35489 ![]() ![]() |
clean it and then check in a few days...
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
From what I can see there is an 'o'ring on the dipstick tube to seal it, this could have failed due to old age.. so if your going to get your hands dirty then an 'o'ring set might be a good idea... also there must be a crankcase breather somewhere, could possibly be blocked and need changing... normally a TD6 issue, but I suppose that it could apply to other LR engines!! Yesterday I couldn't spell Engineer... Today I are one!
Gjlatz Member Since: 15 Feb 2017 Location: Scotland Posts: 12 ![]() ![]() |
Hi guys, thank you for the quick replies. My first thoughts were that the O ring/s had failed. I'll have to source correct part. Can someone confirm if the dipstick tube will simply pull out once unsecured? I have purchased Rave CDs but still await their arrival.
theres a workshop manual download link in the wiki btw.... ... - .- -.
Well guys I've just been out to the Rover and had a look at the basket holding the dipstick tube to the block. what I have done is slacken of the nut and pushed the tube down. A quick look underneath and the gap between the tube and the block has obviously gone. After it has been driven I check for a leak and confirm if this has been a success. |
Hello all, well after loosening the dipstick tube retaining nut and pushing the dipstick tube down fully there was still a leak. I have just removed the dipstick tube and the O ring is still intact, however it does appear to have lost it's shape e.g. flat sides. I have been looking all over web but still cannot find a part number or anyone selling the O ring. I do have a big box of O rings of various sizes but non are a match. Could this be dealer only part?
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Why don't you try Dan from Duckworths. He'll be the one to tell you what's available for your dipstick.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
If you can measure the OD of the groove where the o ring sits and the ID of the hole it pushes into then there are reference charts on the net as to which size it will be.
Hello all,
