Home > Technical (L322) > Oil filter adapter plate leaks 2004 m62 engine 4.4 ,vogue
Louismacrides
United Kingdom 2004 Range Rover Vogue SE 4.4 V8 Epsom Green
Hello does anyone no what the correct name for this is behind the pipe as I think mine leaks oil n wanna no how to fix the leak and see if I can get seals etc
Post #432778 26th Mar 2017 8:22pm
Louismacrides
Post #432849 27th Mar 2017 11:35am
Louismacrides
Post #432850 27th Mar 2017 11:37am
Louismacrides
Here are part number and pictures of adapter plate that bolts to engine case ,the seal in on the inside of adapter plate ,there are also 4 other seal the the feed into and return of oil pipes leading to and from oil filter housing ,these have a slightly different part number but are easy to get on line
Post #432852 27th Mar 2017 11:44am
