![]() | Home > Technical (L322) > Steering pulls to the left |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125 ![]() ![]() ![]() |
Binding Brake maybe? |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 ![]() ![]() ![]() |
I have looked at that aswell but alas no |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
uneven tyre pressures or a buckled wheel, if the latter swop near side to off side and see if that makes a difference.. ... - .- -.
Tried that aswell 😩 |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Leaky front left air bag, compressor can just about cope but after a few bumps that corner is low. Then pulls to the left. Maybe. |
Air bag is ok mr spock live long and prosper 🖐🏻 |
Dragging brake? Collapsing brake hose on front left? |
Also fine been over the front but now it's doing my head in |
Wasn't there an issue with servotronic valves on some cars? I think it was the early ones but search has failed me. That could potentially cause it and would also account for heavy steering. |
If the tracking is good,the air bags are good and the brakes aren't binding thae as just said I'd look at it being the Servotronic Solenoid or body Processor Unit .
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
how about the tyre have it balanced and see if it is ok sometimes tyres can go out of shape |
I have had the codes read nothing coming up also The tyres have been balanced I will investigate this further Thankyou gentlemen 👍 |
If it's showing no codes I would be less inclined to listen to me |
I am rebooking it back into kwick fit for the to go over the car again to see if they have missed anything and will let you know cheers 🍻 |
