Home > Technical (L322) > Steering pulls to the left
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
You can actually check you wheel alignment at home without any special tools. The tolerances the your garage have used may be to large for your particular car, so you may want to check this yourself. You set up a thin line (fishing line) parallell to your car. The height should be on the center of your rims, then you can control that it is parallell by measuring the distance on the rear rim's front and rear edge (there is no toe-in on the rear wheel). These must be equal down to the millimeter. On the front wheel the front edge of rim should then be around 2 mm further in than the rear edge of the front wheel. Do a search on Youtube for a demonstration. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #433535 2nd Apr 2017 8:52am
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
will do on my next day off Thumbs Up Thumbs Up
Post #433608 2nd Apr 2017 9:01pm
Sandyt
Control arm or upper arm?
Post #433871 4th Apr 2017 10:23pm
Simran0211
Thumbs Up will let you know when I get time
Post #434172 7th Apr 2017 3:16pm
Simran0211
For what ever reason the car has stopped pulling to the left and is now ok 🤔 Many thanks for everyone's input 👍
Post #434502 10th Apr 2017 8:51pm
speedymarktd6
Maybe a quiet word , and the test drive in a L405 has made it act proper 😄 onto no6 Range Rover
Everyone needs a hobby
Post #434511 10th Apr 2017 9:21pm
Simran0211
Rolling with laughter
Post #434653 11th Apr 2017 8:23pm
