Home > Technical (L322) > Air Suspension not working, no lights
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
For no reason the EAS has stopped working, there are no lights to indicate level etc, this happened I think while car parked, ie on when switched off and noticed next time I used her no EAS, comes up with warning on dash. Ive checked the 2 fuses listed 57 and 88 and both fine.
Any ideas guys? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #432431 24th Mar 2017 1:03pm
mr_spock
Is it still level and up to normal ride height? Could be compressor failure. If it's down at one corner, air bag. There are other failure modes, but as far as I can tell these are the likely wear & tear items.
What's the error? Just EAS Inactive?
Post #432435 24th Mar 2017 1:54pm
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
I had the same symptoms when my air compressor failed. No lights, nothing on dash although the car was sitting pretty low. 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #432437 24th Mar 2017 2:10pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Lights go out whenever a suspension fault has been occurred, and this could be caused by any one of a fairly large number of things. You could try pressing your 'check control' button - that may give you a suspension fault message (but won't specify what the problem is). Better way would be to use an IID tool or other code reader, if the compressor is goosed you should get a 'pressure static when filling' fault. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #432449 24th Mar 2017 3:17pm
JohnnyDangerous
Thanks guys, compressor sounded fine last time I heard it, shes at correct height and has been for the last 2 weeks, only just done the piston ring in the compressor. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #432461 24th Mar 2017 4:08pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I think if all of the EAS lights are out it indicates a hard fault and only able to be cleared with an IIDtool or the like..... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #432477 24th Mar 2017 5:14pm
JohnnyDangerous
OK cleared the only fault, reservoir losing pressure and its all working again but the reservoir had not lost pressure as the car stayed at the correct height
Ready to tow the other car to warrington
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #432478 24th Mar 2017 5:22pm
The reservoir can be losing pressure and the vehicle will stay at correct height due to the front and rear valves locking off. Possibly problem with reservoir pressure sensor or reservoir control valves block, or a pipe leak somewhere. .
Post #432480 24th Mar 2017 5:25pm
JohnnyDangerous
Thanks, will I hear air escaping? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #432482 24th Mar 2017 5:27pm
Depends on where if a leak .
Post #432486 24th Mar 2017 5:50pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I was pondering the problem of locating leaks today whilst working on my suspension.
I thought maybe a length of hose, one end placed to the ear and the other used in the suspected areas, a bit like a stethoscope?
Worth a try?
Post #432491 24th Mar 2017 5:59pm
JohnnyDangerous
Maybe spray soapy water on it and look for bubbles One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #432511 24th Mar 2017 7:24pm
