Home > Maintenance & Mods (L322) > Gearbox wiring loom seal leaking
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Has anyone changed the seal where the gearbox wiring loom enters the gearbox?
I have just had a service done, and the stealer picked up that this seal was leaking - quote to replace £771.19!!! Big Cry Big Cry
When I queried the cost, they said the majority was for transmission fluid and labour - they would have to remove the harness to fit a new seal - I'm assuming you have to remove the gearbox sump pan and disconnect the harness from inside?
I drained and re-filled the box about 20,000 miles back, and fitted a new sump pan, so I'm considering doing the job myself and saving a few quid - provided it is do-able of course. Would be grateful for anyone else'e experiences. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #432304 23rd Mar 2017 6:46pm
Mikey
It takes around 90 minutes, start to finish
Drain oil
Remove sump
Replace sleeve
Fit new sump
Fill with fresh oil
Post #432344 23rd Mar 2017 9:25pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I followed this. Think it is the same thing.
http://www.fullfatrr.com/forum/topic25131.html 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #432425 24th Mar 2017 1:17pm
Full Fat Ray
Thanks Guys Thumbs Up Thumbs Up , will order a new seal, sump and fluid from Dan.
I note in the photos RR Phil posted, the wiring loom wasn't in the pictures - I assume you disconnect it from the inside of the box and pull it out through the old seal, and then feed it back in through the new seal? 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #432441 24th Mar 2017 3:34pm
the gearbox needs draining simply to get at the release for the sleeve
according to rave you just twist and release the wiring from the outside, then lift the tab and pull out the sleeve. put the new sleve back in with a bit of fluid to lube and put the tab back down and refit the wiring harness.
refit the simp and refill the box.
sounds simple and not nearly £800 quids worth! There is nothing that can't be fixed with a hammer😜😜
Post #432464 24th Mar 2017 5:24pm
Full Fat Ray
Well,all done, at a cost of £300 ish (£10 for seal, the rest on new sump pan and transmission fluid). If anyone else is going to change their sump pan / transmission fluid, I suggest replacing this seal at the same time - if I had known it was a common failure, I would have replaced it 18 months ago when i changed the transmisson fluid - have just had to ditch £175 worth of fluid which had only done 20,000 miles Big Cry Big Cry 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #435556 21st Apr 2017 3:19pm
jonnyboy54321
Well done.
Is this just a failure point on the petrol cars or the diesels as well? Mine wants a box fluid change.. 2007 Vogue TDV8 with 255/55/20's fitted
Post #435570 21st Apr 2017 5:28pm
Mikey
It's an issue on all the 6HP boxes Thumbs Up
Post #435573 21st Apr 2017 6:33pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
If it makes you feel any better , you didn't get all the old oil out originally so all you just lost was diluted old fluid !!! Smile
Post #435636 22nd Apr 2017 8:36pm
Full Fat Ray
No, having changed it 3 times originally, there was very little old fluid in there, which was borne out by the clean colour of what I drained out this time Big Cry 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #436593 1st May 2017 12:32pm
GraemeS
Australia
ZF recommend changing the seal any time the pan is removed to avoid this situation.
Post #436660 1st May 2017 9:45pm
dan_uk_1984
Just a thought - as you knew the oil was fresh, you could have drained it and simply re-used it?
Possibly not something I'd do unless I was very confident of its history, but if you've already changed it three times previously you know it's good.
Post #436727 2nd May 2017 3:13pm
It's a problem keeping it completely clean.
Doable but not recommended unless it can be filtered very well before putting back in. There is nothing that can't be fixed with a hammer😜😜
Post #436766 2nd May 2017 6:49pm
Rangeyman
http://www.roverparts.com/resources/videos...ing-light/ A great video here shows you how it is done !
Post #436814 2nd May 2017 9:24pm
Rangeyman
http://www.jpat.co.uk/ You are as well changing the temp sensor including the transmission harness at the same time,you can get one here for less than £100 delivered
Post #436817 2nd May 2017 9:39pm
