![]() | Home > Technical (L322) > FUEL INJECTION SYSTEM FAILED 14 TIMES |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi thanks for the info;
hi G62
G62 Member Since: 16 Mar 2017 Location: Bergen Posts: 12 ![]() ![]() ![]() |
Hi Bob,
So where do the bubbles in the fuel line come from? |
hi again
hi nicedayforit
I hate to say this but it strikes me there is a leak somewhere on your fuel pipe work that is allowing air to be drawn into the system when the pumps are running but not letting fuel leak out. If you have the fuel tank sufficiently full so that it doesn't matter whether the in tank pump is working or not and bubbles of air can be produced at the secondary fuel pump position by fiddling with the pump it seems the problem is between the fuel tank pick up and the secondary pump. It could be the secondary pump letting air in through the pump body itself but given you have changed this twice it doesn't seem likely. If it was my car I would be concentrating on the condition of the fuel lines for now to totally eliminate any potential problem with them, at least that is a cheap option. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I hope they fitted new o rings when they changed the fuel filter. I had a similar problem on the Pug 407 diesel. I changed the filter with new o rings and the air leak was fixed.
hi guys
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I still firmly believe it is the in-tank pump that is faulty and causing the problems. If the relay was faulty, it would just stop you from starting the vehicle (the relay controls both pumps as they are on the same electrical feed).
hi discotigger
been looking n the search bar at in tank fuel pump posts, and i must say im tending to lean towards this as my problem !!! there are several posts that suggest that partial failure of the tank pump gives exact symptoms as mine ie air bubbles, in filter line, engine cut out, fuel injection system in dash readout etc, and as discotigger also suggests, so perhaps that is the issue,<?
Of the 3 air leaks into the fuel system I've had on 2 different vehicles, neither leaked fuel. One was the Pug 407 at the fuel filter. It would run then stop. The other 2 were in a Isuzu 110, 1 where the lift pump mounted on the motor had a small leak, and earlier an oring on the water separator had a small leak. It would run then stop. ______________________________
If you keep the fuel tank over 3/4 full and run the vehicle gently, you should make it back home without too many dramas. When my in-tank pump started to fail, the engine cut-outs were fairly random and I had 1/2 tank of fuel in. Still managed to run 55 miles to get the car home, brimmed it with fuel and it ran okay till I got my replacement pump.
