Home > Technical (L322) > Hi Ho Hi Ho it's off to supplying dealer I go!
ChuChuRitzy
United Kingdom 2011 Range Rover Vogue SE TDV8 Orkney Grey
Picked up my 2011 vogue SE Sunday
Got suspension errors - normal ride height available only, and now suspension fault
Think it's riding on the bump stops at the rear, if I try to lower the car into access height the front actually rises and goes into extended mode! Meanwhile the rear stays where it is!
What a shame to experience this as soon as I pick it up, fault must have been present.
Seriously unimpressed with both the supplying dealer and the independent they used to check the car when I committed to buying it.
Hope this isn't a sign of things to come and I've bought yet another pup!
Do car dealers just bid low on trade, give it a wash and Hoover, and flog it for £3,000 more??? Seems an expensive valet!
Will the warranty company now have to pay? Or will it eat into some of the dealers margin? If I was a warranty company I'd be hacked off even more!
Post #428883 23rd Feb 2017 8:08am
It varies massively by dealer how much work they do.
Sounds like you're doing the right thing - take it back & let them sort it out.
Post #428884 23rd Feb 2017 8:10am
did these problems not surface on the test drive? ... - .- -.
Post #428885 23rd Feb 2017 8:15am
n1cktdv8
Get it plugged in and the codes read. When mine did this I had it into my local indy and they went through a check process on the computer, then checked the air bags and air lines. You may have a fault on either. Hopefully its a plug n play fix Is this where I put the car details and a bit about myself ?........
Post #428886 23rd Feb 2017 8:17am
ChuChuRitzy
I think the faults were there, but hidden to some extent, as it was locked in access height before I set off, which then after numerous button presses it went to extended, then on getting above the speed limit on that it appeared to correct itself, but on reflection and knowing a bit more that I did then, it was obviously borked!
Post #428889 23rd Feb 2017 9:48am
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Hopefully they nip this one in the bud and fix it for you and its the only issue you have. Its not a great start but dont get disheartened with the car. Your mind will want to make you skeptical and doubting of it every time you get in it otherwise!
Its the reason why when I bought mine the LR dealer had to go and get a coffee, I was raising it up and down rolling it forwards backwards stopping, starting etc still had issues though!
All the best hope it gets sorted.
Post #428946 23rd Feb 2017 7:26pm
ChuChuRitzy
modification required on the air bypass valve apparently, anyone come across this before?
Post #429591 1st Mar 2017 11:14am
ChuChuRitzy
Weeeeee exact same faults have occurred again on the dash! Oh dear! This isn't looking good!
Post #429994 4th Mar 2017 5:30pm
ChuChuRitzy
right thats 9 days i've been without the car so far in just 3 weeks
air suspension fault fixed again
but now someone has put their finger through the engine start stop button!!
FFS!! Big Cry
Post #431499 17th Mar 2017 3:17pm
