Home > Technical (L322) > Hi Ho Hi Ho it's off to supplying dealer I go! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
It varies massively by dealer how much work they do.
23rd Feb 2017 8:10am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
did these problems not surface on the test drive? ... - .- -.
23rd Feb 2017 8:15am |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Get it plugged in and the codes read. When mine did this I had it into my local indy and they went through a check process on the computer, then checked the air bags and air lines. You may have a fault on either. Hopefully its a plug n play fix Is this where I put the car details and a bit about myself ?........ |
23rd Feb 2017 8:17am |
ChuChuRitzy Member Since: 14 Feb 2017 Location: South Yorkshire Posts: 24 |
I think the faults were there, but hidden to some extent, as it was locked in access height before I set off, which then after numerous button presses it went to extended, then on getting above the speed limit on that it appeared to correct itself, but on reflection and knowing a bit more that I did then, it was obviously borked! |
23rd Feb 2017 9:48am |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
Hopefully they nip this one in the bud and fix it for you and its the only issue you have. Its not a great start but dont get disheartened with the car. Your mind will want to make you skeptical and doubting of it every time you get in it otherwise!
23rd Feb 2017 7:26pm |
modification required on the air bypass valve apparently, anyone come across this before? |
1st Mar 2017 11:14am |
Weeeeee exact same faults have occurred again on the dash! Oh dear! This isn't looking good! |
4th Mar 2017 5:30pm |
right thats 9 days i've been without the car so far in just 3 weeks
17th Mar 2017 3:17pm |
