Home > In Car Electronics (L322) > Piggy back fuse issue
alistairh
I've fitted a transcend 220 dash cam and alls went well until I tried to hardwire it into the fuse box.
It works fine plugged straight into the cigar lighter but for some reason it won't power up when it's piggy backed. There's power coming from the fuse point but as soon as I plug in the camera . Nothing.. I'm wondering if it's possible with the extra hard wire cable ect it's possibly too much distance to power the cam. I also have it grounded into a screw behind the vent that sits in the wooden end pieces.. where's the best ground point from the fuse box? .. I have the piggy back attachment wired into a female accessory socket then the transcend cigar lighter attachment plugged in direct... it's probably something simple but it's beaten me ..
Post #430893 12th Mar 2017 8:51am
GraemeS
It wont be due to using a longer wire. Can you hold a length of wire on your earth point and the side of the lighter socket to check the validity of your earth point?
Post #430894 12th Mar 2017 8:56am
alistairh
I shall double check.. actually meant to post this in the l322 section oops! :lol:do you reckon it could be the earth point?
Post #430895 12th Mar 2017 9:03am
moved.. Thumbs Up ... - .- -.
Post #430896 12th Mar 2017 9:09am
Weegie
Do you have a multimeter to check the connections? There is a convenient point to make an earth connection at the fuse box. Will have a look later where I put mine.
As an aside, I piggy backed from fuse No.1 which gives power when in ignition 2 but switch off when on ignition 1. Don't know your camera but mine has an internal battery which continues recording for a short time after switch off.
Previously I had it on another fuse and it was live on ignition 1 which meant when sitting outside waiting for SWMBO with radio playing I was recording whilst stationary. Very Happy John
GAP iiD BT
Post #430897 12th Mar 2017 9:11am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
It will be something very simple. Are you sure the piggy back connector is plugged into a fuse socket providing power? Is the connector fully pushed home? Has the connector got a fuse in it? If you look at the blade fuse you wil see two tiny holes which just allow the tip of a multimeter to be put on to see if it's getting juice.
Can you take some pictures of the install? 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #430899 12th Mar 2017 9:14am
alistairh
@ Stan thankyou 👍..@ wee give that would be great if you could confirm the ground point..
@ slot yeah it's in properly and I've checked it with multiple fuse points with both ignition off and on .. I shall get some photos after work.. thanks guys ..
Post #430903 12th Mar 2017 9:25am
alistairh
# weegie not wee give lol.. iPhone autocorrect at work
Post #430905 12th Mar 2017 9:27am
might typically be one of these, if so try the fuse in the other slot....
Post #430906 12th Mar 2017 9:43am
Weegie
^ +1 if plugging in to an unused fuse point. Otherwise two fuses.
Re earth point, I removed the end panel of the dash and earthed to the metal frame. John
GAP iiD BT
Post #430907 12th Mar 2017 9:49am
SKOT
So based on Stan's pic (above) your dashcam fuse should be in the top (top/right) socket. The lower fuse socket homes whichever fuse (if any) you have taken out. 2006 4.2 SC
Post #430915 12th Mar 2017 10:44am
miggit
Buddy, you want fuse 7.. it's the empty one... comes on with the accessories..... and for your earth, I found a point that was under the cupholder (passenger popout) that was part of the steel frame that supports the dash and earthed there, the biggest problem with the ffrr is a lot of the screws that are self tappers, only go into a clip that is fixed on to a plastic part.. you really have to hunt to find a one that goes into real metal... but as I said there is real metal in the lower half of the dash around the cupholder Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #430927 12th Mar 2017 12:53pm
alistairh
Miggit your a star my man. Fuse 7 and a proper earth has done it Thumbs Up I was earthing it to a screw that was painted and obviously one of the self tappers l.I now have power.. thanks to everyone who's contributed..
Post #430930 12th Mar 2017 1:30pm
Weegie
The problem with fuse 7 is that it is live in ignition 1 position so doesn't switch off when you stop the engine. That's why I went for fuse 1.
Not a problem if you never wait in the car with the radio on. Very Happy John
GAP iiD BT
Post #430933 12th Mar 2017 2:17pm
miggit
^ Why is that a problem?? Surely your never actually going to use it without the engine running, so as long as your not in the habit of leaving the key in the ignition when it's parked then it shouldn't be a issue Rolling Eyes Or have I missed something? Yesterday I couldn't spell Engineer... Today I are one!
Post #430936 12th Mar 2017 2:23pm
