Home > Technical (L322) > am i being stupid or is it broken yet again???
javal322
2005 Range Rover Vogue Td6 Java Black
hi people ,
does anyone know if sport mode and command shift work when the centre console switches are removed? hi/low and hdc?
my panel and switches are currently at a bodyshop having a freshen up and a new sticker , took the l322 for a quick spin earlier on and i dont seem to have sport or command mode?
is this yet another fault ?
TD6 engine 55 plate
Post #430009 4th Mar 2017 7:15pm
javal322
also i cant find anything relating to this on google so im quite stuck
Post #430031 4th Mar 2017 10:52pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I wouldn't imagine that they would work, if you have the electronic swiches unplugged.
haven't had mine apart, but there are one or two plugs under the gear lever that control the gear shift(sport +command). Then of course the switches that control hdc/hi lo, so with these unplugged I'm surprised it's driving with no faults.
Post #430038 5th Mar 2017 6:45am
javal322
mine drives fine in auto but nothing happens in manual mode or sport mode , the only one which i can see is directly linked to the gearshift thats unplugged is a black half moon shape one? no idea what it does
Post #430092 5th Mar 2017 3:53pm
gregdav
Could be linked to the g/box ecu, in which case it won't be receiving any info from the g/lever.
Post #430121 5th Mar 2017 6:32pm
javal322
with no solid answer ( nobody seems to know ) ill have to wait till i get my panels back from the bodyshop , hope its just because theese are unplugged the vehicle is due to go on the road again in the next week or two !
thanks anyway Smile
Post #430135 5th Mar 2017 7:46pm
alistairh
Mines are away getting dipped in piano black. I have zero sport or manual shift in the car. I plugged mine back in before I sent my parts away and the modes returned.. hope that helps Thumbs Up
Post #430137 5th Mar 2017 7:49pm
javal322
exactly the answer i was looking for thank you !
as a coincidence mine are also being done the same , have also done my heater control surrounds ect Smile
phew least its not a big problem , the car is due to go on the road in the next week or two and the panels are going to be a week or so , if there was a problem i wanted to use this time to fix it lol
in that case ill start getting the bits together for the paddleshift upgrade Very Happy
thanks again !
Post #430225 6th Mar 2017 1:17pm
alistairh
it kind of through me at first when mine did it . Really glad I hadn't sent mine away until I had the chance to refit and make sure gear function would return..good taste in interior finishes as well Thumbs Up
Post #430298 6th Mar 2017 9:13pm
javal322
yeah that was my mistake , i didnt notice !
no wonder i thought manual mode had been lazy recently , shows how much i pay attention lol
hopefully have my panels back this week and refit and enjoy having at least one thing working on it!
then its back to fixing dodgy injectors and knackered air suspension
bloody range rovers !
Post #430322 7th Mar 2017 12:20am
