Home > General > Frozen Radiator
bozmandb9
Frozen Radiator
My FFRR 4.4 nearly overheated today, rather ironically. I think it got a bit chilly overnight, and the radiator partially froze up. I was getting no heat from the vents either. I pulled over to let it cool down, then restarted it, and started to get some heat. It was still going up near the red zone before falling though, so I gently limped on to the Indy, where I was headed anyway due to the front door locks being frozen solid.
I've been getting coolant level warning bongs despite the level being fine, so I concluded that it would be a good idea to replace all of the coolant and get it replaced to factory spec, and hopefully it will be a lot more frost resistant, and also get rid of the false warnings.
I'm wondering if it was particularly cold here, I think it may have gone down to -15.
Cheers,
David Range Rover-less at the moment - Pining!
Post #42939 20th Dec 2010 8:30pm
dan_uk_1984
The coolant level sensor also checks the "weight" of the fluid ie the mix of antifreeze in there. If it is less than around 60/40 you will get a message on the dash. As per your owners manual Rolling Eyes
Also the temperature gauge gets its feed from the temperature of the coolant - if the coolant isn't moving due to the rad being flowing then this wont be able to give an accurate reading. So although you may have got to 3/4 on the gauge, more likely you were well into the red.
Fingers crossed you haven't done any serious damage by continuing to drive it (which I really cant fathom why you would do this when a replacement engine is going to cost half the value of the car)
Coolant should be changed every 2 years to keep the antifreeze mix effective. Personally I change it yearly to avoid sludge.
Post #42952 20th Dec 2010 9:22pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
I had the same last week.
I had it drained down and refilled no probs since. 15MY SDV8 Vogue SE
Post #42953 20th Dec 2010 9:30pm
