Home > Technical (L322) > e-diffs?
n1cktdv8
e-diffs?
Is there any order or trim level that the diffs or any other additions were added..
My 2007/8 L322 has 2 padlock symbols that show centre and rear. After a weekend of muddyness on a very sticky caravan site my mates 2012 Westie had just one padlock symbol in the centre.
Optional extra that wasn't selected or part of the update on a later model? Is this where I put the car details and a bit about myself ?........
Post #429393 27th Feb 2017 1:21pm
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I believe the Rear E-diff was standard on S/C models from MY07 only and an option on all other trim and engine choices.
Just checked in an MY06 brochure and no mention of the E-Diff (no terrain response of course at that age)
I have an MY07 brochure due in the post any day so will confirm then 2005 E60 M5
2006 L322 4.2 SC
2020 Tesla Model S Long Range
2004 L322 4.4 Vogue, 2019 NP300 Navara, 2016 NP300 Navara, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C ,2001 330Ci Sport Track Car, 2005 650i Coupe, 2001 P38 Vogue, 2003 530i Sport Touring, 1999 P38 4.6 HSE, 2002 E39 M5, 1995 300zx TT Slicktop, 1997 M3 Evo, 1992 300zx TT Targa, 1998 323i Coupe
Post #429402 27th Feb 2017 2:17pm
rar110
The lock symbol for the rear diff appears whether or not an ediff is fitted on the 07/08 models at least. ______________________________
Post #429413 27th Feb 2017 3:10pm
n1cktdv8
That's a bit naff....
On my way through some mud the symbol was showing locked and unlocked so seemed to be operational - though in truth I couldn't tell if it was locked or not. Is this where I put the car details and a bit about myself ?........
Post #429416 27th Feb 2017 3:16pm
CS
I think that's normal, i.e. the lock symbol alternating between open and closed, when on terrain where you are just getting enough traction to maintain momentum but it's at the margin. Beyond that, when there is more wheelspin and the car is scrabbling for grip I recall another message, in yellow, in addition to the lock symbol. I don't recall feeling the lock going on/off either, though travelling on road and hitting a slippy stretch I do notice the drive being moved around to where traction is best. Only Range Rovers since 1988
Post #429433 27th Feb 2017 5:40pm
Mostly an option - other than as stated, I think the 4.2 S/C had them as standard.
They are a relatively expensive piece of kit that most people really don't need.
Arguably, the display was also accurate - if not fitted, it just showed the rear as unlocked - which is accurate - there was no option to manually lock it anyway, so it only ever displayed the status.
Unless you really know what you're doing, locking diffs can get you into more trouble than they get you out of - I was always taught to use them sparingly as they just get you further from help.....
My best example was a hill climb with deep holes close to the top - caused by spinning front wheels
With the help of my lockers (I could lock all 3), I got further than most -
I still failed.
The guy after me was from the Clarkson school of driving - he also had lockers - but figured more gas would be a good thing -
Without locking diffs, neither of us would have got that far - I was lucky Thumbs Up
Post #429436 27th Feb 2017 6:05pm
CS
Phew. I hope the LR driver was not hurt, other than pride.
Agreed re getting further from help, that can be a feature of mud terrain tyres too. Better to walk the route first if in any doubt about it. Only Range Rovers since 1988
Post #429437 27th Feb 2017 6:28pm
There was a Disco driver coming down the next track who must have Censored himself -
All people OK though thanks to a decent roll cage & harnesses - the LR, not so good.....
Post #429441 27th Feb 2017 6:43pm
n1cktdv8
Mine deffo had both symbols opening and closing padlock and changing colour....
It got itself out of the mess so all good Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #429482 27th Feb 2017 8:59pm
Post #429489 27th Feb 2017 10:13pm
The only way to know for sure is to look at the diff , if it has an actuator motor and a wiring harness Thumbs Up
It's very sensitive to oil contamination with water and crud getting to the clutch plates and reducing your clutch travel percentage .So if you have it and the oil is black , change it . 2008 MY Supercharged
Post #429495 28th Feb 2017 5:18am
GraemeS
Looking forwards at the diff from low behind the vehicle, the ediff's bulging left casting is obvious when compared with an open diff's flat casting with the drive-shaft support protruding from the centre.
Post #429499 28th Feb 2017 7:56am
n1cktdv8
Okay....we're now way into techie zone and way outside my skillset. I'll get under the car when the snow clears and take a picture Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #429503 28th Feb 2017 8:42am
if its an E-diff then it will have a cable/wire going to it..... ... - .- -.
Post #429505 28th Feb 2017 9:05am
GraemeS
The main cable is at the very top and really only visible when looking directly at the top of the diff from behind the top of the left wheel, although 2 wires connect to the oil temperature sensor in the lower left housing obscured by webbing when viewed from the rear. The shape of the left housing is the most accessible distinguishing feature. However selecting rock crawl and neutral or drive to see the colour change is even easier!
Post #429511 28th Feb 2017 10:13am
