Home > Technical (L322) > e-diffs? |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 302 |
I believe the Rear E-diff was standard on S/C models from MY07 only and an option on all other trim and engine choices.
27th Feb 2017 2:17pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
The lock symbol for the rear diff appears whether or not an ediff is fitted on the 07/08 models at least. ______________________________
27th Feb 2017 3:10pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
That's a bit naff....
27th Feb 2017 3:16pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1378 |
I think that's normal, i.e. the lock symbol alternating between open and closed, when on terrain where you are just getting enough traction to maintain momentum but it's at the margin. Beyond that, when there is more wheelspin and the car is scrabbling for grip I recall another message, in yellow, in addition to the lock symbol. I don't recall feeling the lock going on/off either, though travelling on road and hitting a slippy stretch I do notice the drive being moved around to where traction is best. Only Range Rovers since 1988 |
27th Feb 2017 5:40pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7932 |
Mostly an option - other than as stated, I think the 4.2 S/C had them as standard.
27th Feb 2017 6:05pm |
Phew. I hope the LR driver was not hurt, other than pride.
27th Feb 2017 6:28pm |
There was a Disco driver coming down the next track who must have himself -
27th Feb 2017 6:43pm |
Mine deffo had both symbols opening and closing padlock and changing colour....
27th Feb 2017 8:59pm |
27th Feb 2017 10:13pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
The only way to know for sure is to look at the diff , if it has an actuator motor and a wiring harness
28th Feb 2017 5:18am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2480 |
Looking forwards at the diff from low behind the vehicle, the ediff's bulging left casting is obvious when compared with an open diff's flat casting with the drive-shaft support protruding from the centre. |
28th Feb 2017 7:56am |
Okay....we're now way into techie zone and way outside my skillset. I'll get under the car when the snow clears and take a picture Is this where I put the car details and a bit about myself ?........ |
28th Feb 2017 8:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35315 |
if its an E-diff then it will have a cable/wire going to it..... ... - .- -.
28th Feb 2017 9:05am |
The main cable is at the very top and really only visible when looking directly at the top of the diff from behind the top of the left wheel, although 2 wires connect to the oil temperature sensor in the lower left housing obscured by webbing when viewed from the rear. The shape of the left housing is the most accessible distinguishing feature. However selecting rock crawl and neutral or drive to see the colour change is even easier! |
28th Feb 2017 10:13am |
