![]() | Home > Maintenance & Mods (L322) > Sods law strike |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
I'd repair it.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
Why not just refil with coolant and see if you can see where it leaks from ?
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Had similar problem myself 6 months ago. AA diagnosed water pump failure, but turned out to be the top pipe from the radiator to engine block had come off. The pipe sits right above the water pump so is deceiving. It is worth refilling and checking where the coolant is coming from. 56 TDV8 Vogue SE
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1664 ![]() ![]() ![]() |
Failing the above - Charles Kenward Bromsgrove does low loader transport - reliable and helpful. Try this guy for the work he is based in Droitwich. Been my indie for years.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
as stated above 4x4 development droitwich or
