![]() | Home > Maintenance & Mods (L322) > Upper footwell lights |
smudge68 Member Since: 27 Oct 2016 Location: UK Posts: 40 ![]() ![]() ![]() |
Recently did mine and a plastic tool was enough to prize the little |
bigee Member Since: 23 Nov 2012 Location: wales Posts: 58 ![]() |
I'll have to buy a set from the Bay, cheers. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
If you prise the black side panel off, you can push the light and surround out.
I'll give that a whirl in the morning |
I bought a set of trim removal tools - there were about 11 in total for less than a tenner - in preparation for the deployable side step installation, I've got to say they are definitely a good buy for any job that requires trim removal. Did the whole job without even damaging a single clip! |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Very easy to do , i used a small flat head screwdriver and as previous poster said, its held in buy two clips at positions 3 o'clock and 9 o'clock. 2015 4.4 AB
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Mixed opinions on this one.
Does the side panel come off easy enough? |
Yeah not hard, trim tool, or flat screwdriver in and it just pops off! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
it has three clips holding it in, roughly at the pointy bits! I always found the middle popped the easiest, if your worried about the wood / black trim cover the edge with some masking tape... but I never marked mine the 5 / 6 times it was removed |
Success ! Popped off side trims and replaced bulbs without taking the 'rounds' out .... Very tight on passenger side though because of cup holder mechanism.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Did it on mine and I those spot lights were really firmly in place so had to remove the end trim to get to them.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
As Said bwfore Remove the side trim then get your hand in and unclip the clips that hold it in, if you try from the out side you risk damaging the wood or risk breaking the clips . |
