![]() | Home > Maintenance & Mods (L322) > Injectors - recon worth it ? |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
Last summer I had a slight misfire around 60mph on light throttle, which escalated to a shudder when manoeuvring at parking speeds.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
What sort of job is it to do yourself?
The theory of it is straightforward. Good write up in the wiki.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I recently removed and replaced all injectors, took mt 2.5 hours tops taking my time. My injectors came out easily though.
I didn't even have to use service mode on the bonnet. |
It helps if numbers 5 or 6 are being stubborn.... otherwise there is a chance of making your head ache worse |
Biffo Member Since: 26 Aug 2016 Location: Wiltshire Posts: 82 ![]() ![]() ![]() |
Thanks for the great advice ! I like the idea of sending them all off to be tested/cleaned etc. I'll see who I have locally to do that. The Fatty will be off the road for a while (if I ever get the flippin freelander running again) so I can take my time. I'll probably give the inlet manifold a thorough internal clean as well, and replace the thermostat at the same time. I'd like to do the glow plugs, but it seems like a lot of messing for little/no benefit. My fatty has started brilliantly all through the winter, even at -3, and its showing a glow plug fault on the IID. |
The glow plugs, can snap off if your unlucky and require surgery to remove them, just be careful. |
Yep would need to put in service position if it is stubborn, like the same engine used in a Beemer. https://www.youtube.com/watch?v=nK8MqxEeMJY or https://www.youtube.com/watch?v=XwZOTf8vYhE |
