Home > In Car Electronics (L322) > Ipone 30 Pin to Lightning adapter
Sunseekertom
Hi All,
I am wondering if I buy an Apple 30 Pin to Lightning adapter if i will be able to plug my iPhone 7 into the Media cable in the centre arm box of a 2011 AB...
Ideally i would like to be able to play Spotify in the car...
Has anyone else done this? I am wondering whether the 30Pin to Lightning will actually work?
Thank you in advance...
Post #428636 21st Feb 2017 12:24pm
Comments on this thread from NMJ that a genuine one should as it has the digital to analogue convertor - I've not tried it though......
Post #428638 21st Feb 2017 12:31pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Yep it works but would recommend a genuine adaptor. Steep at £25 but they are pinned in the correct way. Some adaptors can only do charging etc, so the safest bet is Apple. Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #428656 21st Feb 2017 3:33pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
The adapters work ok - I brought an after market 30 pin to lightening adapter and use that with the LR cable. I have routed it into the double cup holder so all out of sight. easy job.
I would say however that the fwd and back controls on the steering wheel or the dash do not work so have to use phone display to change tracks. I dont know if this is due to the fact that I went cheap with the adapter and a genuine apple adapter may allow steering controls to work. Question 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #428674 21st Feb 2017 5:45pm
Bebert53
France 2011 Range Rover HSE TDV8 Stornoway Grey
i have done it
the LR adaptator to 30 pin iPod and the Apple to lighting
i have the sound but very low level of sound
what is the problem?
Post #429084 24th Feb 2017 8:46pm
JPHC
Make sure the volume is turned up on the iPhone mate Thumbs Up Jordan
'56 SC 4.2 ‘16-‘18
Post #429088 24th Feb 2017 8:59pm
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
I have it in my 2010MY and works perfect even for controlling my iphone 7
it wont charge the iphone till you get a 5v charging adaptor in it. I tried a few of them and about the best seems to be this one (search for it on ebay) https://www.sonicelectronix.com/item_16295...sPORT.html , although it makes some capacitor noises through the audio system at higher volumes. If anyone knows of a better one or a newer version cable to avoid this, let me know. Current Vehicles :
L322 2010MY TDV8 Autobiography
BMW E38 735i
BMW E63 645ci
Post #431884 21st Mar 2017 12:07pm
Joffa
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I had one. Worked ok with an iPhone 5S but stopped working with my 6S. No idea why.
I have read that the original Apple one works, but other knock odd ones don't.
Personally I'd avoid cables completely & use a Bluetooth adaptor on the end of the iPod cable. I use this one (though there are a few options here).
https://www.viseeousa.com/collections/tune...-connector
Second time I've posted that link on here today. They should give me some bloody commission! Wink
Jof
Post #432809 27th Mar 2017 4:29am
