![]() | Home > Maintenance & Mods (L322) > Reversing lights !!!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35628 ![]() ![]() |
this has been done to death stew, do a search and put aside a few hours for the read.. ... - .- -.
Stew 46 Member Since: 23 Feb 2016 Location: North cornwall Posts: 123 ![]() ![]() ![]() |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
I originally bought 6w LED's. They gave a bulb warning and the light output was rubbish.
javal322 Member Since: 17 Feb 2017 Location: wales Posts: 41 ![]() ![]() |
did you have any issues with the new ones creating warnings? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1462 ![]() ![]() |
I don't suppose anyone has fitted a night vision camera......wouldn't really matter then if you left the rubbish bulbs in..... |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
V8noise - presumably they dont get too hot for the fitting (I realise they aren't on for very long) /. 2007 Vogue TDV8 with 255/55/20's fitted |
No warnings as they are not LED's
The wattage difference is quite small, and, as you say, they are not on long so I suspect heat is not a problem. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The only camera that you'll get is low light... a night vision camera is a massive lump compared with the compact things that are used on cars, I just don't understand why you lot don't want to fit LED's in your existing units.... I just wish that I could find a cheap source of lights... I could retire on the fortune to be made from converting them ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
The Reverse lamps are not monitored by the LCM as they are not a legal requirement ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I have a small boy who lives in the boot space. When I engage reverse it sends a small electric shock to him and he opens the tailgate and shines a powerful torch. Granted it's not the best set up but it was much cheaper than anything LR provide |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 ![]() ![]() ![]() |
I wonder how big the minimum run would be for a Chinese copier, would be very cheap per unit!! |
The Chinese tend to work by the container load when talking cheap... the camera box is roughly 100mm x 75mm x 50mm... I'll leave you to do maths on how many to fill a 40' x 8' x 8' container... suffice it to say it will be more than ten!! Yesterday I couldn't spell Engineer... Today I are one!
thanks for that , ill use the ones you linked above , hopefully that will help ! |
Just fitted the 10w bulbs mentioned above (which arrived fairly quickly) - straight swap - will advise whether they make a difference as and when I've reversed in the dark! 2007 Vogue TDV8 with 255/55/20's fitted |
