Home > In Car Electronics (L322) > HUD for L322 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
where would you get the input from? ... - .- -.
13th Feb 2017 11:08am |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
OBD connect - this one is good.
13th Feb 2017 11:09am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Double glazed windscreen seems to cause some problems seeing the image correctly. Got - 2017 SDV8 Autobiography in Loire Blue
13th Feb 2017 11:19am |
Aftermarket ones only use GPS. You do't get any of the other information the genuine ones have like gear selection, nav instructions and so on. Plus of course, it's yet another damn charging cable to try and hide someplace |
13th Feb 2017 11:44am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Thanks for the replies.
15th Feb 2017 9:41am |
If you were going to use one which connects to the OBD port it would pay you to solder in a piggyback OBD connector up behind the dash. |
17th Feb 2017 9:21am |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
There is sufficient cable on the OBD port for it to be relocated to behind the right side dash side panel, the one the door covers when it is closed. The OBD itself is held in by a clip which slides off and the OBD 'socket' can be removed from the housing. How you mount it behind the side panel is up to you; several (if not most or all) OBDII surrounds will be able to receive the OBD 'socket' and on many there is sufficient plastic on the surround to be able to either attach some basic bracketry or maybe even directly to the metal frame behind the panel. The panel is easily removed by lifting the edge nearest to the seat upwards (two fixings) and then simply sliding out. Hope this helps with your cunning plan. |
17th Feb 2017 5:03pm |
