Home > In Car Electronics (L322) > HUD for L322
rar110
HUD for L322
The price of after market head up display units have come down. Has anyone fitted one to a L322? If so, any feedback?
Thanks. ______________________________
Post #427554 13th Feb 2017 10:50am
where would you get the input from? ... - .- -.
Post #427555 13th Feb 2017 11:08am
OBD connect - this one is good.
Valeo 632051 Head Up Display All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #427556 13th Feb 2017 11:09am
Double glazed windscreen seems to cause some problems seeing the image correctly. Got - 2017 SDV8 Autobiography in Loire Blue
Post #427557 13th Feb 2017 11:19am
mzplcg
Aftermarket ones only use GPS. You do't get any of the other information the genuine ones have like gear selection, nav instructions and so on. Plus of course, it's yet another damn charging cable to try and hide someplace
Post #427563 13th Feb 2017 11:44am
rar110
Thanks for the replies.
OBD is not a good option for these cars given the location of the port is right above the acc pedal.
I'm surprised only Garmin have made a GPS version with speed zone warnings. But none have made one with a navigation function that I can find. ______________________________
Post #427850 15th Feb 2017 9:41am
mzplcg
If you were going to use one which connects to the OBD port it would pay you to solder in a piggyback OBD connector up behind the dash.
Post #428069 17th Feb 2017 9:21am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
There is sufficient cable on the OBD port for it to be relocated to behind the right side dash side panel, the one the door covers when it is closed.
The OBD itself is held in by a clip which slides off and the OBD 'socket' can be removed from the housing. How you mount it behind the side panel is up to you; several (if not most or all) OBDII surrounds will be able to receive the OBD 'socket' and on many there is sufficient plastic on the surround to be able to either attach some basic bracketry or maybe even directly to the metal frame behind the panel.
The panel is easily removed by lifting the edge nearest to the seat upwards (two fixings) and then simply sliding out.
Hope this helps with your cunning plan.
Post #428137 17th Feb 2017 5:03pm
