![]() | Home > Maintenance & Mods (L322) > Engine Cutting Out Intermittently - 2012 4.4 TDV8 |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
Hi,
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
You can ignore the code P040D-00 it never clears and been told/shown that the LR diags show it as a historical fault that clears and then come back. it is due to the tight tolerances of the ECU against that sensor. Regards
When it cuts out, all the electricals are operating and loads of system messages are thrown up on the TFT.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
the compressor is under the spare Bob.. |
I still keep getting intermittent engine cut outs. I had 6 on one day at the weekend. Sometimes it's just for a second, other times it's a complete loss of power and of course power steering and brakes etc.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
Simple things first?
I will double check, but at the point the engine cuts out, there is no visible loss of electrical feed. In fact it's more like the Blackpool Iluminations being switched on in the dash !! |
Ok, drove up the motorway and all ok for 80 miles. Visited Nottingham, but once I was driving around short distances and viable speeds, I ended up with 5 cut outs in close successions. Only one was a blip in the engine beat, the others were full cut out and loss of power to a rolling stop.
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 49 ![]() ![]() ![]() |
Check pressure at fuel rail. |
Will do, what range should it be in ?
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2578 ![]() ![]() ![]() |
I was going to suggest a failing crankshaft position sensor then saw that such a fault was recorded so would be having that checked first. However with the other PCM errors, either directly or indirectly, perhaps there's a loose connection either at the PCM or in an engine harness somewhere. |
Hi there, here is a quick snapshot of Fuel Rail Pressure. It seems to be at about 33060 kPa Any thoughts if this is about right ? |
Anybody know the location of the PCM engine control module (ECM) on a MY2012 TDV8 4.4 ? Thx |
item number one,
