Home > Maintenance & Mods (L322) > Engine Cutting Out Intermittently - 2012 4.4 TDV8
Page 1 of 5 12345>
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi,
I have found that occasionally, my engine has either missed a beat or cut out completely when driving.
I have set up IIDTool, cleared the old stored fault and then checked Faults again.
Model L322 - 2012 4.4 TDV8
I have the following
BCM-Body Control
B1D17-87 (2F) Bus circuit - Bus signal/message failure - missing a message
( on 20-01-2017 14:41:49 at 41218 mi )
B10AD-87 (2F) Rain sensor - Bus signal/message failure - missing a message
PCM-Engine TDV8
P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
( on 20-01-2017 14:41:54 at 41219 mi )
Any ideas ?
Post #424008 20th Jan 2017 5:39pm
proser
You can ignore the code P040D-00 it never clears and been told/shown that the LR diags show it as a historical fault that clears and then come back. it is due to the tight tolerances of the ECU against that sensor. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #424028 20th Jan 2017 8:00pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Almost sounds like a fuel pump is throwing a fit or has a loose connection.......I wouldn't want to lay any money on that though.
When it cuts out, is your TFT screen still lit and all the relevant buttons/knobs still lit? i.e. do you still have electrical power?
Post #424032 20th Jan 2017 8:27pm
bwelton
When it cuts out, all the electricals are operating and loads of system messages are thrown up on the TFT.
Since writing the post, I have also heard some clicking in the boot by the spare wheel. But is that the compressor in there ?
Thx
Post #424036 20th Jan 2017 9:20pm
the compressor is under the spare Bob..
Post #424039 20th Jan 2017 9:53pm
bwelton
I still keep getting intermittent engine cut outs. I had 6 on one day at the weekend. Sometimes it's just for a second, other times it's a complete loss of power and of course power steering and brakes etc.
I took the following fault list afte a complete failure at time stamp: 15:08:##. I have highlighted the fault messages at the point of failure.
However, when the engine blips out for just a second, there are no faults logged.
Any ideas of what could be causing this ?
Below is the fault list. Thx
L322 - Range Rover 2012
Vehicle scanned on 29-01-2017 19:33
Using IIDTool BT V3.0 B2444
AAM-Audio Amplifier
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
( on 29-01-2017 13:21:00 at 66627 km )
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
ABS-Brake Module
U0401-68 (ACool Invalid data received from engine control module/powertrain control module - Algorithm based failure - event information
( on 29-01-2017 15:08:48 at 66635 km )
ADCM-Active Damping
U0401-68 (2C) Invalid data received from engine control module/powertrain control module - Algorithm based failure - event information
( on 29-01-2017 15:08:49 at 66635 km )
BCM-Body Control
( on 29-01-2017 10:47:00 at 66448 km )
B112C-87 (6C) Interior motion sensor - Bus signal/message failure - missing a message
( on 29-01-2017 13:20:10 at 66627 km )
CCM-Cruise Control
U0415-81 (2C) Invalid data received from ABS control module - Bus signal/message failure - invalid serial data received
U0417-81 (2C) Invalid data received from parking brake control module - Bus signal/message failure - invalid serial data received
( on 29-01-2017 17:44:06 at 66651 km )
U0418-68 (2C) Invalid data received from the brake system control module - Algorithm based failure - event information
DCSM - Drivers Clim Seat
B1232-7A (2F) Left seat - Mechanical failure - fluid leak or seal failure
( on 29-01-2017 17:29:28 at 66644 km )
U0140-00 (2Cool Lost communication with body control module
( on 29-01-2017 11:42:08 at 66533 km )
IPC-Instrument Pack
U0128-00 (2C) Lost communication with parking brake control module
( on 29-01-2017 14:47:20 at 66628 km )
PBM-Parking Brake
U0401-00 (2Cool Invalid data received from engine control module/powertrain control module
PCM-Engine TDV8
P0105-16 (6Cool Manifold absolute pressure/barometric circuit - General electrical failure - circuit voltage below threshold
( on 29-01-2017 15:08:51 at 66636 km )
( on 29-01-2017 10:47:05 at 66448 km )
P0336-64 (2Cool Crankshaft position sensor A circuit range/performance - Algorithm based failure - signal plausibility failure
( on 29-01-2017 15:08:48 at 66636 km )
Post #425924 1st Feb 2017 9:59pm
cass
Simple things first?
Loose/poor battery terminal connection?
Post #425930 1st Feb 2017 10:24pm
bwelton
I will double check, but at the point the engine cuts out, there is no visible loss of electrical feed. In fact it's more like the Blackpool Iluminations being switched on in the dash !!
Post #425932 1st Feb 2017 10:38pm
bwelton
Ok, drove up the motorway and all ok for 80 miles. Visited Nottingham, but once I was driving around short distances and viable speeds, I ended up with 5 cut outs in close successions. Only one was a blip in the engine beat, the others were full cut out and loss of power to a rolling stop.
Also, on 3 occasions I could not restart the vehicle.
In this situation, it goes like this
- Driving along fine
- engine cuts out and roll to a safe stop point.
- shut down (Stop button), engine already not running of course, but just shutting all electricals down.
- lock vehicle
- wait 25 seconds
- unlock
- try to start engine
- engine turns over fully and fast speed, but did not fire up
- shutdown and try again
I'm thinking, cut this be a fuel filter, pump or solonoid problem ?
For the 2012 TDV8, what could be causing the cut outs ?
From my previous post, I think the Faults lists (IIDGap) are more symptoms than causes. There are no Faults generated when the vehicle just intermittently cuts out but the engine caries on running.
Any ideas of what I could be or what to check next ?
Thx
Post #426390 5th Feb 2017 11:55am
ipwn
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Check pressure at fuel rail.
Post #426968 8th Feb 2017 9:17pm
bwelton
Will do, what range should it be in ?
Thx
Post #427212 10th Feb 2017 5:15pm
GraemeS
I was going to suggest a failing crankshaft position sensor then saw that such a fault was recorded so would be having that checked first. However with the other PCM errors, either directly or indirectly, perhaps there's a loose connection either at the PCM or in an engine harness somewhere.
Post #427245 10th Feb 2017 9:09pm
bwelton
Hi there, here is a quick snapshot of Fuel Rail Pressure.
It seems to be at about 33060 kPa
Any thoughts if this is about right ?
Post #427281 11th Feb 2017 11:20am
bwelton
Anybody know the location of the PCM engine control module (ECM) on a MY2012 TDV8 4.4 ?
Thx
Post #427307 11th Feb 2017 2:53pm
item number one,
Post #427309 11th Feb 2017 2:58pm
Page 1 of 5 12345>
