Home > Technical (L322) > How to protect amp?
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
How to protect amp?
I have the shedder installed.
But amp took water from underside i dont know how it got wet.
Is thare a way to cover the amp since it is not a hot running amp. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #426732 7th Feb 2017 4:31pm
umitbat
Repaired thanx to a handy local technician for 50USD!!!
Protection suggestions??? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #427270 11th Feb 2017 9:20am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
That's good to hear. To prevent it happening again try fitting a water shedder - Part number EOT500030.
And next time I'll read things properly Rolling Eyes
Post #427289 11th Feb 2017 1:14pm
Dolphinboy
Shedder already installed
Look for a bung/stopper in the bottom of the spare tyre well as there is a drain hole there which will let water in from below if not closed with a bung.
Post #427297 11th Feb 2017 1:34pm
umibat, where is the water coming in from, probably you need to replace/repair the tailgate seal.
I reckon the best way would be to reposition everything in the cubby. Helps if you don't have a sub woofer!
You would need @ 3 inches of water in your spare wheel well before it started to affect the stuff in your cubby. Unlikely that water will make its way in through the bung in the bottom. In fact I reversed my bung and put a hole in it to allow for drainage, even though my wheel well has been dry as a bone for years. .
Post #427298 11th Feb 2017 1:41pm
umitbat
I have the shedder.
The amp damped form underside.
I dried nearly 1 month ago and it is still dry!!
No sign of water yet.
We tried to pressure wash,drived in rain but still dry.
2 months ago we draw in to deep water in higway exit pretty fast at night.
Mybe it got wet then. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #427327 11th Feb 2017 5:35pm
