![]() | Home > My Range Rover > My New Toy!! |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Nice. ______________________________
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Well the Range Roveryness continues.......
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Nice car. |
Well the main reason for getting it is to use it as a back up vehicle if my Mercedes dies when I'm working (Tow for a living), with the ultimate goal of performing an engine and gearbox swap.... was originally going to do a manual pumped 6 pot Merc 24 valve 250 bhp / 450 lbs-ft and a 6 speed box... but it is a squeeze to get it in... and I have just found out that you can do the same with the early 5 pot / 20 valve engines too, and get almost the same power... what could possibly go wrong |
TerryG Member Since: 07 Feb 2017 Location: Midlands Posts: 17 ![]() ![]() ![]() |
Very cool, that's not a conversion i have seen before. Can you buy an appropriate bell housing adapter or are you going to have one machined? |
Not many of those in oz. The VM was quite unpopular around here. Perhaps unfairly. Some converted them to 300TDI.
TerryG, there is a company in Sweden that makes a conversion kit to put an OM606 on to a Range Rover gearbox... but there is a bit of messing about with the oil filters etc... I was intending on buying the engine mounts from them and fitting the OM606 with a 6 speed manual mercedes gearbox, and then mating that to a range Rover transfer box... I found another company that makes an adapter to turn the LT230 transfer box into a stand alone remote box, and they have said that they should be able to produce an adapter that is compatible with the Merc box |
Yesterday I couldn't spell Engineer... Today I are one!
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 504 ![]() ![]() ![]() |
Very very nice car Miggit |
I'm hoping that it wont come to angle grinders at 20 paces because it has had cranked rear arms added recently, and I also think that's what has knocked the stuffing out of the bushes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8519 ![]() ![]() ![]() |
Always found polybushes useless if it's modified, fine in a standard road going car, with the forces the lift put on them they last weeks... always used standard genuine ones and they last ages...
Well it's got cranked arms on the rear so the bush angle isn't too bad, and I'm not planning on throwing it down a ravine or into a bottomless pit, so hopefully they will last a while.....
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 ![]() ![]() ![]() |
Talking about VM diesels..
There are those with VM diesel with just 5 heads.. and two covers...
This is actually a surviving 5-cyl VM prototype. It never went to serial production. Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
