Home > My Range Rover > My New Toy!! |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Nice. ______________________________
7th Feb 2017 7:24am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Well the Range Roveryness continues.......
7th Feb 2017 1:39pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Nice car. |
7th Feb 2017 8:08pm |
ummm.... Nice is pushing it a bit far.... I think it has the potential to be nice, once I've ironed out some of the wrinkles...
7th Feb 2017 11:38pm |
Well the main reason for getting it is to use it as a back up vehicle if my Mercedes dies when I'm working (Tow for a living), with the ultimate goal of performing an engine and gearbox swap.... was originally going to do a manual pumped 6 pot Merc 24 valve 250 bhp / 450 lbs-ft and a 6 speed box... but it is a squeeze to get it in... and I have just found out that you can do the same with the early 5 pot / 20 valve engines too, and get almost the same power... what could possibly go wrong
8th Feb 2017 8:45am |
TerryG Member Since: 07 Feb 2017 Location: Midlands Posts: 17 |
Very cool, that's not a conversion i have seen before. Can you buy an appropriate bell housing adapter or are you going to have one machined? |
8th Feb 2017 9:12am |
Not many of those in oz. The VM was quite unpopular around here. Perhaps unfairly. Some converted them to 300TDI.
8th Feb 2017 9:39am |
TerryG, there is a company in Sweden that makes a conversion kit to put an OM606 on to a Range Rover gearbox... but there is a bit of messing about with the oil filters etc... I was intending on buying the engine mounts from them and fitting the OM606 with a 6 speed manual mercedes gearbox, and then mating that to a range Rover transfer box... I found another company that makes an adapter to turn the LT230 transfer box into a stand alone remote box, and they have said that they should be able to produce an adapter that is compatible with the Merc box
8th Feb 2017 10:13am |
Yesterday I couldn't spell Engineer... Today I are one!
8th Feb 2017 10:16am |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
Very very nice car Miggit ,
8th Feb 2017 2:23pm |
I'm hoping that it wont come to angle grinders at 20 paces because it has had cranked rear arms added recently, and I also think that's what has knocked the stuffing out of the bushes Yesterday I couldn't spell Engineer... Today I are one!
8th Feb 2017 6:05pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Always found polybushes useless if it's modified, fine in a standard road going car, with the forces the lift put on them they last weeks... always used standard genuine ones and they last ages...
9th Feb 2017 5:48pm |
Well it's got cranked arms on the rear so the bush angle isn't too bad, and I'm not planning on throwing it down a ravine or into a bottomless pit, so hopefully they will last a while.....
9th Feb 2017 6:00pm |
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 |
Talking about VM diesels..
10th Feb 2017 8:59pm |
