![]() | Home > Technical (L322) > fuel burning heater |
thegamekeeper Member Since: 12 Nov 2015 Location: sunderland Posts: 71 ![]() ![]() |
plenty of power in the battery but i never heard the burner try to kick in. what shall i try now do you think
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
The fuel pump is a solenoid pump which you should be able to hear clicking. If you can't hear it then either the glow plug isn't glowing which iirc inhibits the fuel pump or the pump is stuck or faulty. The GAP iid diagnostic can read FBH error codes for MY 2010 + vehicles.
thanks for the help mate ile let you know how i get on Current. FFRR Vogue. TD6 Java black.
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I have the same year and model as you, had a quick look under the battery today with a borescope (to lazy to remove the wheel arch) and saw a sticker "66724C" which I assume is the heater but I've never seen anything on my screen about it.
press the top left button on your screen (the one with the big tick on )and the option for the timed climate appears on the bottom right of the screen. set the first time and see if it cuts in Current. FFRR Vogue. TD6 Java black.
Thanks for that.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
What year is your vehicle?
It's a 2006 TD6 HSE.
I had another quick look at this over the weekend and fuse 59 wasn't fitted.
The heater has two functions . One is as a cabin heater where it runs via the screen or remote to heat the cabin and a valve is closed so it doesn't try to heat the engine block and two is where below a set temperature it comes on with the engine to speed up engine warming to achieve better emissions a quickly as possible.
Thanks for that Axle.
