Home > Technical (L322) > Dipping reverse mirror |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
I know that I'm stating the obvious, but did you do the lock to lock sreering reset after battery disconnection. ? |
31st Jan 2017 7:53am |
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 |
I did, as it said air suspension not working or something Not Galway but Balmoral green actually
31st Jan 2017 7:59am |
Just been out and had another go and after 5 minutes of using door control switch to move mirror about it is now working?? Not Galway but Balmoral green actually
31st Jan 2017 11:12am |
Result!!!
31st Jan 2017 5:47pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
It depends on the selector switch for the mirror adjustment - I can't remember which way around but one dips and the other doesn't when you select reverse |
31st Jan 2017 5:56pm |
"it depends on the selector switch for the mirror adjustment - I can't remember which way around but one dips and the other doesn't when you select reverse "
1st Feb 2017 7:44am |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
Mine occasionally does the same, dips, but doesn't undip. If I put it back into reverse again then back into drive that usually sorts it out 2004 Vogue TD6 - Remapped
1st Feb 2017 5:00pm |
