Home > Technical (L322) > Dipping reverse mirror
Waynetab
United Kingdom 2004 Range Rover HSE 4.4 V8 Galway Green
Has worked fine since I bought the car two and a half years ago. Yesterday I fitted a Powerful Uk steering wheel and since then the mirror will dip but not return. I return it by hand but still won't return when drive or park is selected.
I disconnected the battery before fitting the wheel and all the wheel functions work perfectly, getting nice and warm now too.
I have turned off the function but would like to get to the bottom of the problem if I can.
Any ideas?? Not Galway but Balmoral green actually
148,000 miles
Post #425730 31st Jan 2017 8:50am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I know that I'm stating the obvious, but did you do the lock to lock sreering reset after battery disconnection. ?
Post #425732 31st Jan 2017 8:53am
Waynetab
I did, as it said air suspension not working or something Not Galway but Balmoral green actually
148,000 miles
Post #425733 31st Jan 2017 8:59am
Waynetab
Just been out and had another go and after 5 minutes of using door control switch to move mirror about it is now working?? Not Galway but Balmoral green actually
148,000 miles
Post #425750 31st Jan 2017 12:12pm
gregdav
Result!!!
Post #425769 31st Jan 2017 6:47pm
It depends on the selector switch for the mirror adjustment - I can't remember which way around but one dips and the other doesn't when you select reverse Thumbs Up
Post #425770 31st Jan 2017 6:56pm
Waynetab
"it depends on the selector switch for the mirror adjustment - I can't remember which way around but one dips and the other doesn't when you select reverse "
It dipped but didn't return for some reason when put into drive or park.
All seems ok now??? Not Galway but Balmoral green actually
148,000 miles
Post #425825 1st Feb 2017 8:44am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Mine occasionally does the same, dips, but doesn't undip. If I put it back into reverse again then back into drive that usually sorts it out Smile 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #425886 1st Feb 2017 6:00pm
