Home > Off Topic > Passive driver aids - discuss
I do worry that drivers of modern cars have lost or are losing the simple skills of being able to do a hill start or parallel park, or even to manoeuvre a car without parking bleepers.
Like many of you lot, I took my test in an age when cars simply didn't have these things. BSM were using the Metro as learner cars and I had a 1984 Fiesta 1.1L in 1988 when I took my test. I wasn't until my 4th car, nearly 10 years later, that I had the passive safety of ABS in a Peugeot 405 Mi-16. That was also my first car with power steering, electric windows and an engine without a carburettor.
My 110 still does without most things these days, but that's not a problem as I can still do things manually without worry.
My Mustang, with a foot-brake high up on the side of the footwell is the trickiest. To park on a hill, I need to open my looooong door to give me space to move my left leg way, way up to get to the parking brake pedal. Closing the door is easiest with the window open for better leverage. Then I need to reach a long way forward to release the brake with the under-dash pull-lever whilst simultaneously juggling throttle and clutch. Si. <This is my name.
Post #425200 28th Jan 2017 10:45am
miggit
^^ Whistle that'll teach you to go for the complicated three peddle version...or should I say 4 peddle Shocked If it's any consolation I have a 4 peddle Mercedes ML Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #425204 28th Jan 2017 11:18am
Duracell777
miggit wrote:
Hill assist..... isn't that another way of saying Automatic gearbox? Rolling Eyes
What I want to know is, is the emergency stop still part of the driving test? and do they disable the ABS before hand? Cos when I took my test they hadn't started fitting ABS to anything other than the Jensen FF, and I had to use a Renault 6 Shocked
Yes it's nice to have driver aids like cruise control..big help with average speed cameras, but if it was to go wrong..... Rolling Eyes electronic faults in a ffrr, Never Rolling with laughter I'd still be able to stop in an emergency, as I know what to do if the wheels lock up..... Would you? and mores to the point would the spotty teenager behind you?
The 'Controlled Stop' as it is called is still done today (at random, so not all learners will be tested). If the car does not have it fitted, then the pupil will be required to stop without the wheels locking up as has been the case since 1935. (ish)
If the car is fitted with ABS then the pupil must plant the pedal and keep it there until the car comes to a complete stop,,,if they take their foot off before the car stops they will fail.
More and more modern features are being introduced to the test.. such as Sat nav (if fitted)
Aids are and should be just that..aids..
If drivers didn't drive badly, we probably wouldn't need driver aids. Cause and effect.
Good drivers shouldn't need rules BUT we have them because we are not all good drivers.
Aids should enhance not replace good driving practice.
Post #425208 28th Jan 2017 12:24pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Quote:
I presume you're not disabled, as I am sure some disabled drivers would find these things invaluable
Please don't go down that route, this has nothing to do with special equipment for those, who through no fault of their own, need vehicles adapting to their needs.
Quote:
Have you actually tried the park assist on a L405? By the time it's found a space big enough you'll find a coach has nipped in before you Laughing
This is actually a valid point! Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #425212 28th Jan 2017 1:02pm
miggit
Whistle Hill Assist does not put the bloody brakes on going down hill.... That is HILL DECENT CONTROL.... hill assist disengages the handbrake when you step on the loud pedal Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #425216 28th Jan 2017 1:30pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
It's SatNav that I worry about more. The next generation seems to have very little sense of direction and an aversion to maps (though it might just be my kids). My 21yo son will get to the end of our road and ask "get or right?".
Post #425219 28th Jan 2017 1:35pm
Rob99
You're on a sticky one there, so I'm not going to continue this aspect of the debate any further 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #425222 28th Jan 2017 2:03pm
RR2008HSE
It's the march of technology. I remember looking at a 100 year old Rolls Royce. The driver was expected to adjust the engine timing using a lever on the steering wheel. Who needs to 'adjust the points' or clean their carburetors anymore? When did you last read that the 'choke is automatic' was being used as a selling feature?
Yes, I can drive a manual transmission without rolling back on a hill, and could do so since I was 11, but a non-synchro gearbox. Well, I've done it on a LR 2A, but I sure wouldn't want to have to do it during a driving test.
The modern aids are only a problem if the driver thinks he isn't responsible himself. When changing lanes, you need to check your blind spot, whether you have blind spot monitoring or not.
Post #425459 29th Jan 2017 7:37pm
miggit
I personally think that "Driver Aids" should be not present when learning to drive.. that way at least they will know what it feels like if a system goes down in later years... I know what it feels like when the car wheels lock under heavy braking and when the tyres are getting to the edge of their grip in a corner. While it maybe a surprise to find your ABS has failed under heavy braking, I would know to ease off the stop switch and try again... What would a younger driver do?
I have noticed that the more safety features become available to the average motorist the worse the standard of driving is... because your less likely to die in a crash, modern day drivers don't pay as much attention to self preservation, the net result is there are more crashes because some muppet was following too closely or going around a corner too fast.
Who remembers the disastrous Mercedes launch of the Radar Braking system... where they forgot to turn the system on and stuffed the car in front of the press Rolling Eyes And then a lot of those systems rely on optical sensors, below the bumper on the front of the car.... Whistle that is really going to work well on a dirty wet road... say with salt on it.... Rolling Eyes
Yes it can be argued that modern safety systems help save lives... but I think you'll find that they also lower the standard of driving and level of skill in car control...... Yesterday I couldn't spell Engineer... Today I are one!
Post #425542 30th Jan 2017 7:39am
miggit
How long before you can take your test in one of these.............
Post #425544 30th Jan 2017 7:46am
rvbush
And there lies a problem. People do not accept personal responsibility as much as they did and the issue with blind spot monitors is very simple, people SHOULD check their blind spot, but they won't if they have monitors, they'll rely on the monitor. Same with all passive aids. Then, one day they are driving a car that doesn't have them, except they will forget and drive into everyone. And the excuse? Not my fault, I usually drive a car that does all this stuff for me!!
Absolutely, but these are the aids I've classed as Active, as none of them do the driving for you.
I have to come back on this Rob:
Be fair, it wasn't actually me who mentioned it. Drives:
Post #425547 30th Jan 2017 8:00am
Rob99
I was probably having a bad day Whistle 2021 D350 Fifty Edition - Carpathian Grey
Post #425624 30th Jan 2017 1:59pm
RR2008HSE
Rvbush
Good points. Thumbs Up
Post #425714 31st Jan 2017 3:59am
