Home > Technical (L322) > Battery Recommendations
Page 3 of 5 <12345>
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
AGM without a doubt Thumbs Up
Post #425095 27th Jan 2017 7:05pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Does it matter if my old one isn't AGM ?, ie do I need to do a like for like swap,or doesn't it matter ?
Post #425099 27th Jan 2017 7:14pm
stu_007
2006 Range Rover Vogue 4.4 V8 Tangiers Orange
Genuine LR for me. "YYS" G4 FFRR
G4 2006 Thailand Support Vehicle - Fleet Number 81
Post #425101 27th Jan 2017 7:26pm
AusRR
Australia 2003 Range Rover HSE 4.4 V8 Zambezi Silver
Ive only had good experiences with AGM
Post #425114 27th Jan 2017 9:32pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
KRV24 wrote:
However I have an OEM battery (VARTA) and its a 12v 90ah 850A AGM which suggests its a bit weak for a MY2010 fatty? Pinged an email to the local Indy and got a supply and fit quote of 295.00 which seems steep (or not?). Need to check exactly what they will be supplying.
That is the same battery I fitted to our motor around this time last year. Bought as new old stock, but nationwide 2 year LandRover warranty.
It replaced a 12v 90ah 950A (EN) 7H42-10655-EB JLR battery, part number YGD500130.
Best thing I ever did swapping to an AGM battery.
Using the park heater twice a day early morning and 20 mins before finishing work, no worries whether it will start or not. This was early last year after fitting it and even more since we have had this long drawn out cold spell starting before Christmas.
Never changed the settings/software for AGM from a standard battery.
Had the large Varta 110ah 920a, not a patch on the AGM battery, so that debunks the amp hour/cold cranking amps saga.
Go AGM, more expensive, but less fear of not starting. An AGM has a better recovery rate should you inadvertently flatten it. Flatten a wet cell battery and you can reduce its lifespan by 50%.
Also the above size means you don't have to shoehorn it into the battery compartment.
The Varta silver I1/Bosch S5 at 393mm long would not fit into our 2007 TDV8 without a serious mod to the positive terminal clamp.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #425118 27th Jan 2017 9:44pm
J evro
Is it likely I will have to change settings if I go for an AGM one then ?
Post #425129 28th Jan 2017 12:16am
miggit
AGM have a higher charge voltage than a normal battery.... BUT, they are more expensive than a normal battery, they only carry a maximum warranty of 3 years, and they have a smaller capacity than the 020 Rolling Eyes
If your car has an AGM as standard then you'll have to stay with them, but if your car is an older ffrr (I don't think that AGM was fitted before 2010) then fitting an 020 will give you better bang for your buck.... and out of those that are available I would go for a Varta 020 silver, can be brought for just over £110 delivered and has a 5 year warranty.... plus Varta batteries were used by Land Rover, so your fitting OEM / Genuine just with out the Land Rover badge and the £100 markup Whistle
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Yesterday I couldn't spell Engineer... Today I are one!
Post #425164 28th Jan 2017 9:49am
J evro
Thanks Miggit, that explains a lot 👍
I'm not with mine today so can't check but it's a 2008 so presume not an AGM,
Is the Varta 020 silver an AGM battery ?
Post #425196 28th Jan 2017 11:12am
miggit
No the Varta 020 is a lead acid battery and has a 5 year warranty, the AGM version is an H15 and only carries a 3 year warranty, plus it's 105 amp hour instead of the 110 Ah that the 020 is Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #425197 28th Jan 2017 11:17am
JackRegan
The original battery fitted to my 2010 (2011MY) 5.0sc was also a Varta - 90Ah 800 Amps
 2024 P550e Autobiography
2016MY TDV6 Autobiography - Gone
2011MY 5.0 SC Autobiography Black - Gone
2005 TD6 Vogue - Gone
Post #425198 28th Jan 2017 11:24am
miggit
The petrol engined cars had a smaller battery fitted, an 019, but the larger 020 will fit... they are the same height and width, but the 020 is about an inch longer Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #425199 28th Jan 2017 11:30am
J evro
Please make my mind up for me
Got to go get a new battery tomorrow ,
Been reading all the battery posts but just can't decide between ...
A Varta Silver
Or
An AGM Battery
What would you do ?
Post #425448 29th Jan 2017 7:21pm
vaz
AGM.
Your motor is around 6-12 months older than ours. Ours was fitted with a standard flooded cell battery, I changed to an AGM, didn't alter any software (don't know if it is possible on pre 2010 motors).
Charge voltage went up from 14.3 volts after a start up to 14.7 volts, this taking into account that an AGM usually needs a higher charge voltage.
Motor has been fine ever since (fitted for a year now).
Quite a few others on here are going down the AGM route and seemingly not regretting it.
Post #425516 29th Jan 2017 11:45pm
J evro
Post #425517 29th Jan 2017 11:53pm
miggit
Shocked
AGM batteries are primarily leisure batteries designed for deep discharge.. basically they are for stop / start eco cars as they have a high duty cycle. Unless your doing lots of short journeys with the occasional long run there is no real advantage to an AGM.. they were fitted to later cars because of the remote FBH feature. They require the higher voltage for charging so that they recover more quickly, after a certain level has been reached they charging circuit reverts to the lower 14.1 volts to finish the recharge off.
While an AGM will work on a normal system OK, you wont be getting any of the benefits of the technology as the charging circuit isn't designed to charge at different rates. So fitting an AGM will give you a battery that is 50% more expensive, with a lower capacity than a normal battery and will come with a warranty that is 3/5 ths shorter than a std battery...
So if you want to pay more for less that will run out quicker, go ahead Rolling Eyes But it really doesn't compute....
Get the 020 Varta and You'll have the largest battery that will fit without hassle, and give you the largest capacity available with the longest warranty.... My battery was a Varta and the car was 13 years old when I changed it, while I don't for one moment think it was the factory fit battery, I believe it was the second battery the car has seen, so it would be fair to assume that they managed to go for 6.5 years each before they gave up Bow down
Whistle If Varta give a 5 year warranty, so you can bet they have tested them well beyond... they aren't in the business of giving them away Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #425548 30th Jan 2017 9:11am
Page 3 of 5 <12345>
