![]() | Home > Technical (L322) > Plea for Advice Before My Wife Kills Me... |
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
I also run a 4.4 with Prins LPG, but I've never heard of anything like that before! That is really strange....
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6415 ![]() ![]() |
Welcome to the forum!
Class_5 Member Since: 01 Jan 2017 Location: Yateley Posts: 29 ![]() ![]() |
Thanks for the reply - was almost convinced to problem was fuel related - failing pump or 'bad' petrol, as all seemed to be fine running on LPG. But as I said, I noticed the idle speed is a couple of hundred above normal now when switched to LPG.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Classic fuel pump on it's way out... buy a pump for an X5 and take your one fuel pump assembly apart and just fit the X5 pump to your assembly..... much, much cheaper than a FF one... |
Digger7820 Member Since: 04 Jan 2016 Location: Brigg Posts: 28 ![]() ![]() ![]() |
I had a classic many years ago running lPG and had no problems starting on LPG ,summer or winter.
Thanks all so much for the quick replies |
Has it always been high on LPG? I think mine does idle slightly higher on gas than on petrol. NW060
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
SWMBO's comment seems to be a common theme for many ff owners. I agree I would start with the filter as the cheapest option (and keep your fingers crossed) but keep another one handy in case there is anything in the pipes. Is it possible to get foreign object debris when filling a car nowadays? Many years ago I had a Mk1 Capri that had intermittent fuel starvation and it turned out to be small crumbs of cork in the tank. No idea how they got there, but after flushing the tank and the fuel system every thing worked perfectly. Yes I know cars didn't come with lockable fuel caps then and somebody could have put them in, but especially after the oil crisis in the early 70's they were readily available and mine had one. QUID FACIUM TIBI
Hello Mat777 - idle at neutral on LPG and petrol has always been identical (about 650), now both are up to about 900.
Try cleaning the MAF.
....... Pete
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I know nothing about LPG and don't have it but when mine idles at 900 or higher it means the battery is low and the car enters a recharge strategy until it has charged it up enough which is normally after a good run. |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
As Pete said, fuel pump. I did everything else to try to avoid it (MAF, fuel filter etc) but in the end had to bite the bullet. |
Thanks for the replies, very much appreciated.
