![]() | Home > Technical (L322) > So what's the problem? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Sticking fuel pump, freed itself up?
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
Thanks. Would the cold make it stick? I know diesel can wax up, but I only use Shell V Power or BP ultimate, both of which in their winter formulation shouldn't wax up. |
It's a FFRR, it knows when you really need to get from A to B and therefore likes to throw the odd spanner in the works leaving you stranded... The joy of FFRR ownership |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
Could be the crankshaft sensor. If the crankshaft sensor is at fault the ECU doesn't even register the fact the engine is turning over so it won't even attempt to fire therefore no fault codes stored either. I've had this on a few cars over the years.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3660 ![]() ![]() |
Heard from the dealer today. Low pressure fuel pump is the culprit, which is to be replaced under extended warranty. Pleased its sorted. |
