Home > Technical (L322) > So what's the problem? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8500 |
Sticking fuel pump, freed itself up?
23rd Jan 2017 9:25pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1015 |
Thanks. Would the cold make it stick? I know diesel can wax up, but I only use Shell V Power or BP ultimate, both of which in their winter formulation shouldn't wax up. |
23rd Jan 2017 9:41pm |
It's a FFRR, it knows when you really need to get from A to B and therefore likes to throw the odd spanner in the works leaving you stranded... The joy of FFRR ownership |
23rd Jan 2017 10:04pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3066 |
Could be the crankshaft sensor. If the crankshaft sensor is at fault the ECU doesn't even register the fact the engine is turning over so it won't even attempt to fire therefore no fault codes stored either. I've had this on a few cars over the years.
23rd Jan 2017 10:56pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
if any sensor is sending the wrong signal or no signal the ECU will record it..... so you need to be looking for some thing that isn't monitored... like water.. in the fuel and blocking the fuel system, or a batch of fuel that hasn't got quite as much anti wax in it as claimed. All winter diesel has anti wax mixed in it.. cos if it didn't it wouldn't come out of the pump, however the pump (fuel station) is less exposed than the fuel system on a car... so maybe a cold wind did blow on that fateful day and the fuel system froze over Yesterday I couldn't spell Engineer... Today I are one!
23rd Jan 2017 11:09pm |
23rd Jan 2017 11:12pm |
Does not compute if stops the engine from running then it should be stored.. not that I'm doubting you, it just doesn't make sense.. however if this is true, maybe the dealer can unplug it to see if the same fault occurs, and check the sensor for cracks... I imagine that it's a Hall effect sensor and a bit of moisture and sub zero temps would render it inoperable Yesterday I couldn't spell Engineer... Today I are one!
23rd Jan 2017 11:41pm |
Heard from the dealer today. Low pressure fuel pump is the culprit, which is to be replaced under extended warranty. Pleased its sorted. |
25th Jan 2017 8:19pm |
Well that should have been recorded, as it throws up a fault code Yesterday I couldn't spell Engineer... Today I are one!
25th Jan 2017 10:37pm |
