Home > Technical (L322) > Power cable to speed camera warning device |
Mudplugger Member Since: 20 Feb 2009 Location: err... near Inglewhite, Lancs. Posts: 95 |
I need to get a power cable connected to the speed camera warning device I have mounted on the plastic binnacle in the windscreen area above the RHS air vent (and wood trim).
27th Mar 2009 1:17am |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
There should be a Perm Live in the lower Kick Panel (The Plastic bit by your right foot) |
27th Mar 2009 6:51am |
Thanks Ken,
27th Mar 2009 4:06pm |
pull the vent out first then unscrew the rest of the trim |
27th Mar 2009 4:11pm |
Any clips inside the vent as usual? Range Rover Vogue SE SDV8 - L405 (now sadly sold)
27th Mar 2009 4:13pm |
Yep a good pull will work fine |
27th Mar 2009 7:50pm |
Thanks Ken. Range Rover Vogue SE SDV8 - L405 (now sadly sold)
27th Mar 2009 11:05pm |
look in RRUK's post re TV on the move you will see the vent out then the screws
28th Mar 2009 7:14am |
All done!
28th Mar 2009 10:09pm |
mintleaf Member Since: 28 Mar 2009 Location: London Posts: 19 |
All sorted now...cheers |
9th May 2009 6:38pm |
alexbartman Member Since: 08 Dec 2009 Location: UK Posts: 43 |
I'm trying to do exactly the same fit with my Pogo - can you help me out with kick panel removal and then picking the right wires for live and earth.....any advice gratefully received!
9th Dec 2009 8:16am |
tucker_j Member Since: 01 May 2010 Location: Kent Posts: 14 |
Hi All,
1st May 2010 10:31am |
Sorry I'd not picked up on these posts earlier.
15th May 2010 11:34pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
I mounted mine in the same location - on the plastic binnacle in the windscreen area above the RHS air vent and wood trim. But did a really simple installation.
17th May 2010 9:54am |
